RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   os .40 fsr users guide (https://www.rcuniverse.com/forum/glow-engines-114/3631529-os-40-fsr-users-guide.html)
sco215 12-08-2005 12:26 PM
anyone out there have a users guide (manual) for the os .40FSR. need to know breakin needle settings ect.[sm=RAINFRO.gif]
jaka 12-08-2005 12:38 PM
RE: os .40 fsr users guide
Hi!
There isn't such a thing as a rule to this...just run it rich if it's ringed and fairly fast if it's an ABC engine! that's it!
2 1/2 -3turns open is just a start.
Regards!
Jan K
Sweden
Flyboy Dave 12-08-2005 06:22 PM
There are no specs given in the manuals, I just checked two of them. Mine
are both ringed engines. 2 and 1/2 turns out on the main sounds about right.
There is a seperate instruction page for the carb, it doesn't say anything either.
FBD. ;)
downunder 12-08-2005 09:20 PM
Back in the FSR era there were only two types of engine you could get, ringed or cast iron. Everyone knew that for either of them you just ran them slobbering rich at first and the only danger was a needle that wasn't open enough. :)
Personally I like to start a new engine with the needle screwed out maybe 3 or 4 turns and the throttle opened enough not to have to worry about idle mix.
sco215 12-08-2005 09:35 PM
so im getting runum RICH! anyone have the mounting dimensions or a link to some drawings specs ect ( .40 FSR ) for my engine is out for repair and i want to get this mount tapped.
Flyboy Dave 12-08-2005 10:36 PM
1 Attachment(s)
Here Ya' go....(hope this helps)....[sm=thumbup.gif]
FBD. ;)
sco215 12-08-2005 10:46 PM
that helps tons:D can i get the width of the engine @ center of mounting holes? and thanks again this is a big help [sm=RAINFRO.gif]
sco215 12-08-2005 10:48 PM
also the 18mm is that the holes center or is it the full lenth of the mounting beam
Flyboy Dave 12-08-2005 10:54 PM
The 18mm is the center of the mounting holes, lemme go measure the width.
Flyboy Dave 12-08-2005 11:20 PM
1 Attachment(s)
[sm=thumbup.gif]
sco215 12-08-2005 11:28 PM
thanks FBD, you have been a great help. this site is fantastic the peaple here are great. what did we do before the internet!! thanks again for giving me your time and help. scott
Flyboy Dave 12-08-2005 11:34 PM
No problem Scott....good luck with the engine. ;)
Dave. :D
