Which tachometer
I need to buy a tachometer digital tachometer. I've never owned one before. Which ones should I be looking for? Which ones should I stay away from?
I'm looking for the cheapest one (of course!) that will give a good steady reading, and will not need replacing for a couple years. Thanks, Juice |
Which tachometer
Juice,
This doesn't exactly answer your question but I thought you needed to know that the TNC is one of the best tachs you can buy and If you compare it side beside a cheap one, you'll never have anything but a TNC. They are not made anymore but a Guy on here is in the process of purchasing the rights and should have some before spring. Do a search on here for TNC or for Tach and you will come across the story. Enjoy, Jim |
Which tachometer
they are also about 5 times the price of the so called cheap ones...
The thread was titled digital tachs. |
Good Tach.
Hey Juice,
Four years ago the "Thunder Tiger Digital" tach. was recommended to me and hasn't let me down yet. They are listed at www.greathobbies.com for $56 cdn. Part # is TTT2642. Take all your tach readings from BEHIND the prop. This tach. works in all kinds of natural light. I've seen here a number of fellows can't get a reading from behind the prop only in the front? If your not getting a reading from the left side of the engine, try the right! If you still do not get a reading, turn the plane 90 deg. or even 180. This is a good tach for the $$. I know some guys at our field were having problems with the "Globee" and that might be one to stay away from. Happy Fly'n.... |
Globee works fine fer me
Oh well, here's the Globee fix again http://www.rcuniverse.com/showthread...655#post491743]
Black Tach.
The Thunder Tiger Tachs are solid black, so one does not have to worry about that. Just don't leave it out in the sun!
Happy Fly'n... |
| All times are GMT -8. The time now is 12:32 PM. |
