Carb adjustment
I have a K&B 40 that i am reassembling after cleaning. What would the base needle settings on the carb be. I need a starting point so i'll be in the ballpark.
RE: Carb adjustment
About 3 turns out
RE: Carb adjustment
That would be the idle mixture screw right? What about the top screw on the carb. Is that the high speed adjustment?
RE: Carb adjustment
There's several different carbs on the K&B 40. None of which has a top screw that does anything but change the throttle minimum position in order to change the idle speed.
http://www.mecoa.com/kb/40/40-parts.htm |
