RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Test Bench (https://www.rcuniverse.com/forum/glow-engines-114/4704711-test-bench.html)
skeeter_ca 09-03-2006 12:37 PM
Test Bench
Need to build a test bench to run my K&B. I have a engine stand but it's not mounted to anything. What do you guys have. How do you set up a throttle control and fuel system.
w8ye 09-03-2006 12:40 PM
RE: Test Bench
1 Attachment(s)
Here's my Saito 150 on an American Hobby Products Jumbo stand
skeeter_ca 09-03-2006 12:47 PM
RE: Test Bench
How do you control the throttle?
papion007 09-03-2006 12:59 PM
RE: Test Bench
What I do is run your pushrod thru the rubber bands holding your tank..I have an Enya 120 4/s and K&B 61 they work just fine
hooked up that way.Just pull or push the pushwire,to rev or idle.Make sure all nuts and bolts are tight and stand behind the engine. I used two pieces of aluminum angle brackets mounted to plywood,drilled holes for the mount.
Pappy
carrellh 09-03-2006 03:18 PM
RE: Test Bench
1 Attachment(s)
ORIGINAL: skeeter_ca
My brother built one from boards and spare parts. For throttle control, he used a servo, receiver, and battery. The receiver was a multiple crash victim. He doesn’t trust it for flying but it can’t cause a lot of problems where it is now.
The servo holds the throttle position steady even if it’s not powered up.
Cyclic Hardover 09-03-2006 06:35 PM
RE: Test Bench
ORIGINAL: w8ye
W8ye's photo reminds of when I use to bench run engines. (I don't anymore.) I had a ST 4500. I mounted it to the front of a wooden sawhorse, then sat on the saw horse for weight and let that thing go!!!!! I bet if I had wheels on that thing, I would have had a heck of a ride
wjvail 09-03-2006 08:08 PM
RE: Test Bench
http://www.rcuniverse.com/forum/m_44...tm.htm#4458549
This thread may help...
Bill Vail
Jimmbbo 09-03-2006 10:59 PM
RE: Test Bench
1 Attachment(s)
Here's mine... simple, small, light and cheap... my top four criteria :D
Clamp it to a Workmate or work bench at the field
Cheers!
Jim
opjose 09-05-2006 01:00 PM
RE: Test Bench
I went with something home built similiar to Jimmbbo's but a bit more elaborate.
One piece of 1/4" wood was used to build the whole thing.
I drop the test bench into a Black and Decker shop mate. THe Shop Mate clamps a piece of wood which hangs from the main board of the bench.
The motor mount is elevated on a crude wood square that has a tank mount aside it.
A pushrod attached to a simple handle acts as a throttle.
It took about 20 minutes to build with epoxy and drywall screws.
Works great, less filling.
