RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Sc91fs (https://www.rcuniverse.com/forum/glow-engines-114/523057-sc91fs.html)
andywragg 01-31-2003 03:58 PM
Sc91fs
I have a brand new, never been run SC91FS that I bought for my top-flite spit 1X. I would be interested to hear from anyone with one of these engines, to give run-in tips and general advice, types of plug etc... This is my first 4 stroke lump, please be kind....
Does anyone have one of these engines in a top-flite spit?
w8ye 01-31-2003 06:23 PM
Sc91fs
There are several different brands of engines that are made by the same company.
SC, ASP, & Magnum are all identical.
If you want to read a review of this engine, go to www.justengines.unseen.org and read the review on the ASP 91
I have one and it is a friendly easy to adjust engine. It has power compariable to the OS FS91 Surpass I engine.
Treat it as you have your 2 stroke engines. Except if you get it too lean, it will back fire, tear up the spinner and or throw the prop off. Always have a smoke trail.
Enjoy,
Jim
CharlieDelta 02-01-2003 12:23 AM
Sc91fs
My ASP91FS is doing great with about 60 flights.
Only one dead stick and always starts after a few seconds on a starter. Low tickover, instant throttle, not too heavy, runs inverted etc.
Dont run it weak as said before. Mine went off the boil and I noticed the camshaft looking decidely dry so now after every session I pump a couple of CCs of oil down the breather pipe - performance is back to its best.
Mine turns a Master 13X8 prop really well. I dont have the clearance for a 14X6 which might be the prop of choice.
andywragg 02-01-2003 12:26 PM
Sc91fs
Thanks for the reply's guys, I plan to use a 3 blade 13/14x 6 so I get plenty of ground clearance. 3 blade cos only the very first spits had a 2 blade job up front, and I want it to look the part. I know the MK 1X had a 4 blade prop, but these are hard to get in the UK (at a low price anyway). Besides I cant be arsed changing props, and I dont foresee entering any scale contests.
I've also read some pretty scary performance theory (elsewhere in this forum) on 3/4 blade props for small planes. The 3 blade prop would seem to be a reasonable trade-off between appearance, ground clearance and performance.
ta-ra for now
Andy
