RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   OS 61 FX Problem (https://www.rcuniverse.com/forum/glow-engines-114/5299911-os-61-fx-problem.html)
rednekk58 01-21-2007 01:36 PM
OS 61 FX Problem
Hi People,
Have an OS 61 FX with less than a gallon of fuel through it before I nosed it into frozen terra firma. It was in a U-Can-Do 46. Well I just put it in a Cap 232 and noticed the spinner backplate wobbling as I hand propped it. Put a neww crank then reinstalled it, took the glow plug out and spun it with a starter. At the end of a 13" prop I get about an 1/8 to a 1/4 in run out.
Any one have any ideas? I don't have a dial indicator. Couuld it be the backplate behind the spinner?
Red
w8ye 01-21-2007 01:47 PM
RE: OS 61 FX Problem
Did you install a new crank in the engine?
I bought a crashed engine one time understanding that the crank was bent. - Turned out that it was a busted prop drive washer.
If a spinner was in a crash and wobbles, then it needs to be replaced
on pipe 01-21-2007 02:37 PM
Has to almost be the prop drive washer, or the prop warped. Ross
rednekk58 01-21-2007 02:39 PM
Thanks w8ye
New spinner, new crank. Was your drive washer just bent or cracked?
rednekk58 01-21-2007 03:33 PM
Thanks guys,
Just tried two other props with same resulults, this time no spinner backplate. I think the gap between the drive washer and the engine casing changes slightly. Not easy to see with these old eyes.:) Going to order a new one.
Thanks again.
over 25 years and only bent a crank once, along with the engine casing breaking. Into the ice that one, then the garbage.
w8ye 01-21-2007 05:13 PM
My engine with the bent crank experience was a Saito 182 twin that got shot down. The drive washer was on the crank crooked. Not taking any chances, I just installed a new drive washer. The problem went away.
buzzingb 01-21-2007 05:32 PM
With the cost of OS parts why try to repair? Just order a Super Tiger probally won't be much higher than parts to fix OS.
rednekk58 01-21-2007 05:51 PM
Hey Buzz,
You right, but its too late. Totale of the parts so far has been about a $100 clams
Will have to remember that tip.
buzzingb 01-21-2007 10:43 PM
Your welcome, I have been where you are before and I know first hand how expensive the OS parts can be. I ran two 61FXs and a 46FX before switching over to Super Tiger.
