RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Evolution 46 Leak (https://www.rcuniverse.com/forum/glow-engines-114/5664602-evolution-46-leak.html)
Celidon 04-04-2007 01:06 PM
Evolution 46 Leak
I have an Evolution 46 that I crashed last fall. It went nose first into the pavement. When I fired it back up on a new plane this spring it had a leak around the prop shaft at the front of the engine. I replaced teh front bearing but I still have a drip leak. Should I replace the shaft also? Any other ideas on wht might be causing this leak? The crank case does not show any cracks.
Flyboy Dave 04-04-2007 11:01 PM
RE: Evolution 46 Leak
A small leak at the front is no big deal, but is the crank bent ? The new bearing you
installed....was it plain (bare balls) shielded, or rubber shielded ? The front bearing
may have enlarged the front of the case where the outer race of the bearing fits, due
to the impact of the crash. [:o]
This may be the cause of the leak as well.
FBD. ;)
