RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   ? Cox .049 Engine (https://www.rcuniverse.com/forum/glow-engines-114/579227-cox-049-engine.html)
oakman40 02-24-2003 02:00 AM
? Cox .049 Engine
1 Attachment(s)
I have three .049 engine and I have such a hard time to start them, they are all the same wen I start them cold, I have to use a needle and put a couple of drop of fuel on the cylinder, I do that a couple of times be-for it starts, some times 10 times. Do any one have a few hints for me on the proper way to start a .049 engine.
Thanks!
Yvon
Quicker 02-24-2003 02:18 AM
? Cox .049 Engine
Don't know about the engine, but cool SPAD!
mscic-RCU 02-24-2003 03:15 AM
? Cox .049 Engine
1/2a engines like nitro. try 30% nitro and i bet it starts easier. I fly mine on 15% and it can be hard to start at times.
jmercer52 02-24-2003 03:24 AM
? Cox .049 Engine
Fuel draw is a problem with these engines. Primming is the real trick. A hot glow starter is needed too. And like MSCIC said, they like a lot of nitro. I started using an electric starter on mine and is sure works good! A lot better than flippin!
Duane-RCU 02-24-2003 04:31 AM
? Cox .049 Engine
I always set the needle valve about 1/2-1.0 turn rich, then they start with less priming, then, lean it out!
oakman40 02-25-2003 01:59 AM
Cox .049 engine
Thanks guys for all the good info! :)
Oakman40
