Conversion
Does anyone know what the conversion from metric to inches is. Like a 3.5 equals a .21. What does a 4.9 equal out to? Thanks in advance.[:o]
RE: Conversion
4.9 is .29
Scott |
RE: Conversion
3.5 x 0.061 = .21
4.9 x 0.061 = .30 convert it other way around .30 x 16.3872 = 4.9 Borna |
RE: Conversion
RE: Conversion
ORIGINAL: yankee samurai Does anyone know what the conversion from metric to inches is. Like a 3.5 equals a .21. What does a 4.9 equal out to? Thanks in advance.[:o] If you divide inches by six you get the metric volume =cc. For example a 60sized engine is 10cc. A 30cc engine is 1.8 cu.in. sometimes also called 180. |
RE: Conversion
Easy to find the conversion as here:
1" are 2.54 cm, to find the volume of 1 cu.in: 2.54 cm x 2.54 cm x 2.54 cm = 16.38 cubic centimetre To example how big are the engine in cc when the engine are at 0.40 cu.in: 16.38 cc x 0.40 cu.in = 6.552 cc To example how big are the engine in cu.in when the engine are at 15 cc: 15 cc / 16.38 cc = 0.91 cu.in ;) |
RE: Conversion
Go get the converter program from http://joshmadison.com/software/convert/ as it's the neatest program you'll find to convert just about anything to anything else (with the possible exception of shoe sizes :)).
http://joshmadison.com/software/convert/download.php takes you direct to the download page. |
| All times are GMT -8. The time now is 09:12 PM. |
