PROBLEM WITH AN OLDER ROSSI
I have an older (carb input at the rear) .61 ROSSI engine. I put a MASTER AIRSCREW prop on it and I can barerly get the hold down nut onto it.
Q) how do I extend my prop shaft so that I can get the nut on 100% --- let alone some kind of spinner. marwen1 |
RE: PROBLEM WITH AN OLDER ROSSI
....you have a ducted fan engine, with a short stud. Get a nut and a bolt with the
same thread as the engine. Thread the nut onto the bolt,and chuck the bolt up in a lathe. Leave about 1/4 of the nut alone, and turn down the other 3/4 round until you have about 1/8" "meat" left from where the threads are. Now you need a thin washer that fits onto your turned-down nut. You have to bore out the hole in the prop, so your new nut fits into in. It's a "counter-bored prop now. ;) FBD. :D |
[quote]ORIGINAL: Flyboy Dave ....you have a ducted fan engine, with a short stud. unquote] Very probably so. This .61 has also been bored out to a .81 and from I'm told, the last time it was even used was in a fan jet system Q) Any idea what RPM I should be able to turn? & Q) what fuel should I use? I amgoing to use this as a PUSHER PROP ASYSTEM on a bumped up FORCE ONE. From the normal 36.5"WS to a 60"WS DELTRA WING. MARWEN1 |
Doesn't Fox still make prop extentions ? ( crankshaft extention )
Tru Turn has a short shaft spinner adapter...
Would that do in this case? |
1 Attachment(s)
Hi!
What you do is this! You get an aluminium spinner nut with a treaded flange that extends inside the prop. Or if you have a Tru Turn alu spinner...a nut with a flange that goes inside the prop. How many do you want? |
1 Attachment(s)
....you need one of these, only in size 8X1.25, this is the wrong thread pitch.
This Rossi shaft should have the same thread as yours. Rossi .45 & .61 show the same size and thread pitch. FBD. |
1 Attachment(s)
....here it is, click on TRU 0826 :D It's the short shaft kit, with the correct thread. ;)
http://www.chiefaircraft.com/rcmsec/...s/TruTurn.html FBD. :D |
.....the ones jaka has will work with no spinner. ;)
I think that Tru Turn is the way to go. I sent BOB at Tru-Turn an email telling him what I have and left it up to him to tell me what I need to make my ROSSI work with the MASTER AIRSCREW 3 blade PUSHER PROP that I have on it now.
Much thanks my fellow RCers. Some times I have to wonder how in heck did I EVER manage to build anything before this forum came along Y'all have a GREAT day! marwen1 |
| All times are GMT -8. The time now is 01:13 PM. |
