Inverted or Side mounted Engine!
HI All!
I want to mount a ST75 on my new Model (YAK-3, W/S is 65 inch weigth is at 4.5 kg) and was thinking ......... is it worth to mount the engine inverted?? Considering all the problems that this will have?? Or is it better to have the Head stiking out of the Cowling. Since it is a War bird and true to scale! Any tips since I have never had an inverted 2 stoiker. Regards Erick! |
Hi,
All engines made for airplanes are build the way that they can work in any position. I have 8 airplanes, engines in all kind of positions (side, uspsidedown, straight). Never had any problems. But if you needles are not set right, you engine will not work good in any positions ! (sorry for my bad English) |
Upright or Horizontal
Originally posted by Alexandre But if you needles are not set right, you engine will not work good in any positions ! |
I had some start problems when my engine was inverted , (upp side down)
:confused: |
| All times are GMT -8. The time now is 03:38 PM. |
