RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   What engine??? (https://www.rcuniverse.com/forum/glow-engines-114/7161945-what-engine.html)
FrancisPerson 03-01-2008 05:38 PM
What engine???
I am about to start a SIG Ultimate fun Fly. I "want" an ENYA .50 ring because I like ENYA and it only weighs 15.2oz, however it is about $175. A OS FX .46 is $100 from Omni models. I want to keep the weight down as much as I can as lighter flys better.
As an FYI my ENYA .45 CX turns a APC 12x4 at 12,500 and a MECOA .46 turns it at 12,000.
Any body own a ENYA .50 ring? How strong?
Francis
Hobbsy 03-01-2008 07:37 PM
RE: What engine???
Francis, I know we talked on the phone the other night, Is my .50 CXTN the same as your .45CX, I could run a Graupner 12x5 on it if you need some numbers.
Hobbsy 03-01-2008 08:08 PM
RE: What engine???
1 Attachment(s)
Here it is, it weighs 16.7oz with stock muffler and 18.7oz with the MDS .58 baffled muffler I use on it.
Rcpilot 03-01-2008 08:31 PM
RE: What engine???
It's got plenty of wing area for the weight. Thats the whole idea of a profile.
I flew mine with an OS 61FX. This was YEARS ago before the Tower .75 and lighter engines came around. At the time, it was either a .60 or you had to jump to the next class-- the .90 engines. I knew a .90 was too big.
Mine flew fine with the 61FX. Were I to build the same kit today, I'd probably use a TH .75. It's lighter than a 61FX and lots more power.
I realize your flying a a much lower elevation than me, so your standard .46--.50 engine will work. Why not try the OS 55AX? Or the Magnum 52XLS? The OS is expensive. I wouldn't buy it for that reason. They run decent, but overpriced for me. The Magnum is usually a good deal. I have the .46XLS and really like it. OS quality and running characteristics with a good price tag.
blw 03-01-2008 09:20 PM
RE: What engine???
There is also the option of the Evolution .52 if considering your choices. It has a noticeable amount of more power over the ringed .50SX. Parts are much cheaper.
FlyingPilgrim 03-01-2008 10:18 PM
RE: What engine???
I don't think you can go wrong with an Enya as far as quality. Another option, if you wanted to go large, would be the gold head Twister .61 from K&B. Less weight than other brands, supposed to have good power, and on sale for $100.00.
alcarafa 03-02-2008 02:04 AM
RE: What engine???
Magnum 52 XLS = 18000 rpm's enough for you ? also a low price 89.99 at towerhobbies, outstanding engine.
asmund 03-02-2008 08:38 AM
RE: What engine???
A friend odf mine (yallaair) just broke in a new XLS 52. Completely stock, no mods at all it turned APC 12-4 at 13900 rpm on 15%
WhiteRook 03-02-2008 09:39 AM
RE: What engine???
alot of 2 strokes are too light , you need the weight up front especially on a short nose
airplane, thats why alot of people go to gas engines. if it balances out with a light
engine , fine. lighter does fly better , but the bird has to balance.
FrancisPerson 03-02-2008 10:13 AM
RE: What engine???
I am concerned about balance but the SIG kits I have built ended up balancing where thay should. Goldberg kits are tail heavy so from the beginning of the build I try to move things forward to compensate. I did that on a SIG 4*40 and had to add a bit of lead to the tail:( .
