Two questions
First- Recently i crashed my plane with a O.S. 46LA and destroyed my plane. Upon further inspection of the engine i found the smallest, smallest bend in the crankshaft up from the point where the threads end on the engine. i have rotated the engine by hand and it rolls smooth as ever. Is this a problem?
P.S. i basically already know the answer ( its a problem) but i am just checking with the vast knolage on rcu to make myself 100% sure. Question two- Will this http://www3.towerhobbies.com/cgi-bin...&I=LXCH46&P=OW work as a replacement crank? |
RE: Two questions
ORIGINAL: panzertank First- Recently i crashed my plane with a O.S. 46LA and destroyed my plane. Upon further inspection of the engine i found the smallest, smallest bend in the crankshaft up from the point where the threads end on the engine. i have rotated the engine by hand and it rolls smooth as ever. Is this a problem? P.S. i basically already know the answer ( its a problem) but i am just checking with the vast knolage on rcu to make myself 100% sure. http://www.rcuniverse.com/forum/m_6948801/tm.htm ORIGINAL: panzertank Question two- Will this http://www3.towerhobbies.com/cgi-bin...&I=LXCH46&P=OW work as a replacement crank? |
| All times are GMT -8. The time now is 06:44 AM. |
