RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Zero Nitro heads? (https://www.rcuniverse.com/forum/glow-engines-114/7606006-zero-nitro-heads.html)
jeffie8696 06-13-2008 11:29 PM
RE: Zero Nitro heads?
I will have to do some measuring to check the quench area of the Aviastar. But my email is down due to the flood so I am only here with yall tonight because I am at my daughters house using the computer. [:o]
djlyon 06-14-2008 12:44 AM
Hey good luck with the high water and keep feet dry
jeffie8696 06-14-2008 11:33 PM
Luckily my house is on high ground. :D I did a test with my Aviastar using SIG FAI 0% nitro fuel. I had to adjust the compression by removing all the head shims and use a very hot plug but it ran great!!! Only lost 50 rpms over 5%nitro. Let the NHRA have the nitro , I can still fly. :)
