Any one using JBA075A or dependable substitute?
I would like to power my US60 (under construction) with a 0.75 engine. I would like it to be a TH-0.75 but still out-of-stock. So, I have been searching for possible substitutions.
I see the OS-75AX as the last option due to its cost only. I know performance and reliability are there. Then, I have been looking at the JBA075A and supertigre, which is out of stock too. So, Is there anyone using this engine or would like to provide a recommendation of a dependable substitution? Thanks in advance, Pedro |
RE: Any one using JBA075A or dependable substitute?
1 Attachment(s)
....the ASP .91 two strokes are available....do a search. ;)
Mucho power....little money. :D FBD. :D |
This Magnum 91 is a very nice engine too! I believe it is identical to an ASP, but the Magnum seems to be more readily available in the US. I REALLY like mine!
http://www.hobbypeople.net/gallery/210806.asp |
Oh yeah... The weight of a 91 is very little to no more than a 61, so a 91 will work very well on a 60 sized model. You just have to be a little careful you don't rip the wings off! :D
The SK90 is hard to beat from a value for money perspective.
JBA 75 is on same weight with JBA 91
1 Attachment(s)
As Turk says, the JBA .75 and .91 weigh the same. The .61, .75 & .91 are all built in the same case. The best one to buy is the largest, the JBA .91.
I have had an SK 90 and an Evo 100 on my US 60. The SK 90 requires a 15-6 prop so a longer gear or bigger wheels might be needed. I also have a couple of Tower .75s and they like a smaller prop. They really hum on an 11-8 or 12-6. I would pick the JBA .91. |
ORIGINAL: Ed_Moorman I have had an SK 90 and an Evo 100 on my US 60. The SK 90 requires a 15-6 prop so a longer gear or bigger wheels might be needed. For $65 or so it's hard to beat the SK for value. |
ORIGINAL: XJet ORIGINAL: Ed_Moorman I have had an SK 90 and an Evo 100 on my US 60. The SK 90 requires a 15-6 prop so a longer gear or bigger wheels might be needed. For $65 or so it's hard to beat the SK for value. |
ORIGINAL: Ken6PPC ORIGINAL: XJet ORIGINAL: Ed_Moorman I have had an SK 90 and an Evo 100 on my US 60. The SK 90 requires a 15-6 prop so a longer gear or bigger wheels might be needed. For $65 or so it's hard to beat the SK for value. |
That link is to a supplier in China. Not only will you have to pay for shipping from China, but you will have limited warranty support, at best. Buying one for $100 might be cheaper in the long run.
This is a quote from the article about the SK 90 on RC Reviews (I believe our very own XJet wrote this): At this stage I have to issue a caveat in respect to my experiences with SK engines. This particular example from the SK factory is indeed a great little engine but I had far less joy with an SK50 I purchased at the same time. This SK50 will be the subject of another review to be published shortly. However, it's fair to say that it is obvious that a factory which can produce engines at both ends of the quality spectrum has real issues with quality control. I therefore issue my standard warning when it comes to the purchase of products that sport the "Made in China" label... Don't be tempted to buy an SK engine from a dealer or distributor that doesn't perform pre-sales inspections and checks of the product. While you might save a few dollars buy purchasing directly from China, there's always the chance that you'll have wasted money rather than saved it. If your engine is a dud, the only option you have is to ship it back to China for a replacement which will almost certainly be uneconomical. Do yourself a favor and buy from a local dealer with a good reputation for after-sales support. It'll likely be cheaper in the long run. It doesn't appear that the SK 90 is quite the bargain that it seemed to be at first glance, but a purchaser in the US can have one delivered for a little over $100. That is still pretty cheap for a 90! |
You're right I would advise anyone in the USA (where KangeUSA is the authorized distributor I believe) to buy locally and take advantage of the extra measure of quality control and support they've been proven to offer.
Those who live in countries where SK has no official support will just have to take their chances and import direct from China. |
And also Kangkeusa has different and better Q/C standarts than Chinese shops.(Proven by 40+ units from Kangkeusa)
ORIGINAL: Ken6PPC This Magnum 91 is a very nice engine too! I believe it is identical to an ASP, but the Magnum seems to be more readily available in the US. I REALLY like mine! http://www.hobbypeople.net/gallery/210806.asp ORIGINAL: Flyboy Dave ....the ASP .91 two strokes are available....do a search. ;) Mucho power....little money. :D FBD. :D |
The Magnum and ASP are the same engine but the SK90 is a completely different unit with markedly different characteristics.
Sorry. Yes, that's the SC that it similar to APS and Magnum... And DC as written here http://www.himodel.com/engines/A15A_...Airplanes.html
I have a JBA 75 and all of the SK engine line. The JBA 75 and the SK 70 are identical except for engine porting (and the paint job). The JBA ports are higher, like a standard port engine, where the SK are lower, thereby lowering RPM but increasing torque.
Thanks to everyone for your feedback. It has been very helpfull.
| All times are GMT -8. The time now is 08:37 PM. |
