RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   OS 160 FX + custom header + MVVS pipe (https://www.rcuniverse.com/forum/glow-engines-114/8087159-os-160-fx-custom-header-mvvs-pipe.html)
liquid_TR 10-26-2008 06:23 PM
Hi all,
Ive just finished rebuilding an OS 160FX with a new liner+piston and ring. I'll break it in with a normal OS F glow plug using 18x6 prop and 0% nitro fuel with Bisson Pitts Muffler.
Ive hooked up a new CDI ignition to the engine as well, once its broken in, I'll switch it to ignition.
Now here is the thing: This engine will go into a World Models Spot On 120 Pattern ship.
I'll be using a MVVS 3266 tuned pipe with it. For header, I gave an order for building a custom header to Just Engines last week.
Once I got the custom header, how am I going to tune this pipe for midrange authority?
I bet its not as easy as peak tuning it just for max rpm.
I'll use this setup for serious pattern practice.
I guess the props I can use are APC 17x10, 18x8, 18.1x10 - or I can go with a JXF 18x8 wood prop (as its wide enough for downline braking)
How do I set it up? cutting the header again? or just use it as it is?
PS: On another note, do i certainly need to use a perry pump with it? (the fuel tank is located behind firewall)
Thank you for your input. :)
