RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Engine cleaning question (https://www.rcuniverse.com/forum/glow-engines-114/8166262-engine-cleaning-question.html)
F4U Corsair 11-20-2008 01:05 PM
For those of you who have used the antifreeze in the crock pot method for cleaning your engines, do you need to dissasemble the engine into pieces? I know you have to remove the carb because of the o-ring and seals, but what about the rest of the engine, ie bearings, rings, etc. If you cover the holes (carb/glow plug) will the antifreeze damage any of the engine internals if it seeps in? Thanks, DG
w8ye 11-20-2008 01:08 PM
RE: Engine cleaning question
Take the back plate off the engine also
The antifreeze will not hurt the internals but you need to get it out of there when you are done
ProBroJoe 11-20-2008 05:06 PM
The hot antifreeze really does a nice job of loosening up all the gummy castor residue and makes it easier to disassemble further, so yea, just pull the carb and any plastic rubber bit that you don't have replacements for and dunk the sucker with the glow plug and backplate removed.
If you're hesitant to use antifreeze and a dedicated crock pot, then Dawn Power Dissolver is your next best bet... I've used both methods and it's pretty much down to whether or not I can get the engine apart - if it's stuck or gummy with dried castor oil, I'll just remove what I can and drop it in the antifreeze. If I can disassemble the engine then I use the Dawn.
Either method works well, but both require a certain level of safety precautions... The antifreeze is a poison and the Dawn is a caustic chemical. [:'(]
Hope this helps,
-Joe
rainedave 11-20-2008 08:13 PM
Scroll down to post #306 in the link below to see what I did with Dawn Power Dissolver and Wright's Copper Cream:
http://www.rcuniverse.com/forum/fb.asp?m=8166199
David
jetpack 11-21-2008 11:51 PM
I really wouldn't trust anything but breaking it all down and using a stainless steel brush over everything and a good hot soapy scrub, and a clean rub with a towel to see if the towel picks up any dirt.
I've tried to clean whole assemblies before in the crock pot and just like it was mentioned it is good at helping take things apart but cant really be trusted in my opinion to just rinse and use.
Motorboy 11-22-2008 12:10 AM
If you can not like the fume of the antifreeze, see this link: http://www.rcuniverse.com/forum/fb.asp?m=7962214 ;)
