RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Best prop for tt pro36? (https://www.rcuniverse.com/forum/glow-engines-114/827273-best-prop-tt-pro36.html)
Crash90 06-02-2003 09:03 PM
i am looking for a happy medium between speed and torque. Maybe leaning towards torque. Thanks.
dhooks 06-02-2003 11:21 PM
Depends on your airframe but try a 10x5.
Crash90 06-02-2003 11:24 PM
thanks. It will be going on a SPAD. Kombat20.
rsieminski 06-03-2003 12:22 AM
How much does the plane weigh? Draggy or sleek?
ben flyn 06-03-2003 12:51 AM
9 X 7!!!!!
Crash90 06-03-2003 02:41 AM
Box says 3lbs. Sleek i think.
Pepe J 06-03-2003 03:00 AM
TT Pro .36 Prop.
APC 10 x 6 or 11 x 5 should do the job for you.
I run the 10 x 6 on mine. Good speed, excellent torque at 12500 RPM.
Happy Fly'n....
rsieminski 06-03-2003 03:54 AM
Ben's right 9x6 or 7. Very fast!
ben flyn 06-03-2003 05:58 AM
On my Pizza box, an 11X3; on my combat, 9X7! Pure torque or pure speed!
f2racer 06-11-2003 04:54 PM
I use an 11x3 on my Uproar 40 with amazing results. Definitely unlimited vertical. Hover and vertical pull outs without issue. I've also put an 10x5 on the same setup which gives it less thrust more speed (less fun), but tops out at about the same rpm. Haven't tried a 10x4, but if it gained another thousand rpm or so, it may take similar thrust to the 11x3...
Enjoy!
