RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Puller needed for drive washer... (https://www.rcuniverse.com/forum/glow-engines-114/8347903-puller-needed-drive-washer.html)
flyby50 01-11-2009 11:15 PM
Hello, i would like to ask what type of puller you guys use for removal of the drive washer, no auto parts stores seem to carry the battery post puller, i did have one but it was junk, i see some on line but i thought i better ask, thanks, flyby50....
ace4-40 01-11-2009 11:44 PM
RE: Puller needed for drive washer...
1 Attachment(s)
OS makes a very nice puller that works on their 40 to 61 size engines as well as the many OS clones. You can also buy a small gear puller that works very well. They aren't cheap but work great.
w8ye 01-12-2009 12:23 AM
I use one of these to grip the hub then use a puller to pull the whole thing off
http://www.harborfreight.com/cpi/cta...temnumber=7343
http://www.harborfreight.com/cpi/cta...emnumber=93980
You can usually buy these at the auto parts or industrial supply store but they often try to gouge you for $100 for the set
wjvail 01-12-2009 08:23 AM
I have used one of these for decades. I've never found a drive washer it can't remove (although sometimes a little heat helps).
http://www.sears.com/shc/s/p_10153_12605_00999018000P
Bill
Charley 01-12-2009 08:04 PM
ORIGINAL: flyby50
I have a battery terminal puller from Sears that's a real beauty. Nice wide jaws, lots of range. Hafd it a long time but it may still be available.
CR
flyby50 01-13-2009 08:00 AM
Thanks guys for your help, i'll get out and see what i can find, flyby50....
JRO 01-13-2009 10:26 AM
When I replaced the bearings in a couple of my engines, I went to Auto Zone and they let me use their puller in their store. Auto Zone is just down the street from me. If I were to do engines all the time I would buy a puller.
Ken6PPC 01-13-2009 07:58 PM
I bought one of these:
I was lucky enough to find it on sale for $29.99.
Yes, it probably is overkill, but it works SO well..... I can be pretty confident that I can pull any thrust washer I will ever need to, and I can use it for other pulling operations as well.
w8ye 01-13-2009 09:52 PM
Good deal on the puller.
You get on a big block Saito that's been jammed into the ground and you will need a little heat on the hub to get it off even with that outfit. So you didn't do an over kill by any means
Ken6PPC 01-13-2009 10:02 PM
ORIGINAL: w8ye
Who would EVER jam a Saito into the ground? [sm=75_75.gif]
[sm=red_smile.gif]
[sm=lol.gif]
asmund 01-14-2009 03:24 AM
Battery terminal puller are great, it is very cheap here in Norway and should cost only a couple of bucks in the US.
w8ye 01-14-2009 12:18 PM
My experience with battery terminal pullers is that they are not strong enough to work on any of my engines that have a taper collet type prop drive hub. The fingers slip off and mare the finish on the hub. They just do not have the power to get the job done. They are just a waste of money.
asmund 01-14-2009 01:41 PM
Mine works great, you must have bad ones over there, he he[sm=lol.gif]
w8ye 01-14-2009 03:18 PM
I have a K-D just like the one Bill Vail has. It's in the tool box out in the garage. I just use it for battery terminals. It works great for that.
flyby50 01-14-2009 03:38 PM
Hello, is it cold enough for you :), i'm going with the one from harbor freight, should i get both things you listed or just the kit, thanks everyone for your help..... [sm=thumbup.gif]
w8ye 01-14-2009 03:45 PM
just the kit will be fine.
It was 5F below zero last night and supposed to be colder tonight and has snowed all day and night.
flyby50 01-14-2009 03:55 PM
Ok thanks, i'll get the kit, i brought the bunny in last night, he is sleeping away in the basement, he likes the smell of my coat ( after run oil ) and he makes my garden grow :D, keep warm, and thanks...
