RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   need help - FOX Engine Model/size? (https://www.rcuniverse.com/forum/glow-engines-114/8424477-need-help-fox-engine-model-size.html)
pmillerusa 01-31-2009 09:18 PM
1 Attachment(s)
Picked this up with a garage sale Zero
Says FOX on the carb, but no other marking whatsoever. I measured the bore and stroke and came up with .89cu" (so a 90?). The case is 2 piece with the second half on the back split right across the cylinder centerline. Will add another photo later (tear down)
Was gummed up bad, but turns nice now. Low speed needle was broken as well as the ring having fractures (came out in 3 pieces)
Anywhere to get parts for these? I didn's see them on the FOX Mfg site...
Thoughts?
w8ye 01-31-2009 09:48 PM
RE: need help - FOX Engine Model/size?
You can get a ring from Frank Bowman
[email protected]
Frank C. Bowman
1211 N Allen Ave.
Farmington, NM 87401
505 327 0696
for new bearings http://www.bocabearings.com/
I don't know that they ever made a 90. They made a 78 and a 74
kersplat 01-31-2009 10:24 PM
It is a Fox .74. You can get a ring from Fox as well. If you go with Frank Bowman, you may need to send the engine so he can custom fit it.
w8ye 01-31-2009 10:55 PM
doesn't look like it was ever run?
Maybe just you cleaned it before the picture?
pmillerusa 02-01-2009 12:07 AM
1 Attachment(s)
it looks like it has a few miles on it for sure.
the ring had a number of cracks in it and it came out in 3 pieces.
thanks for the info on the parts. I used a machinists ruler to measure the bore and stroke (Don't have my mic or calipers here) but I dont think it was as small as .74 or .78 based on the crude measurements....
I'll give Frank a call and go from there...
thanks again!
Ram Jet 02-01-2009 12:36 AM
On the head with w8ye.
Bill
Ram Jet 02-01-2009 12:37 AM
Doubt it.
Bill
w8ye 02-01-2009 12:54 AM
you are going to need bearings too
pmillerusa 02-02-2009 12:06 AM
Thanks.. Between how the bearings look (and now that it's loosened up) how they feel, it'll certainly need bearings.
I remeasured and then used the right formula (misplaced the brackets in the piR2xH the first time)
Came up with 0.53495552 using more accurate measurements and the right formula.
Would this be a .50 then? not sure if they made a .53 or .54. Cannot find a lot of info on their engines. Surprised I couldn't find any other marking than what was on the carb.
Calling FOX in the AM to see what they come up with.
w8ye 02-02-2009 12:31 AM
you should find Fox to be very friendly and informative.
Lou Crane 02-02-2009 01:54 AM
Paul,
I know Fox made a .60 and .74 in this configuration. Certainly it is not a .50 or .55...
Fox Mfg should be able to sort things out. If you don't feel a need to buy a bunch of new parts, consider a crock-pot/antifreeze soak to clear away the congealed castor. The ring, definitely, needs to be replaced if it is cracked and broken as you said. Unless the cylinder bore got scored by it, you may get off lucky.
DarZeelon 02-02-2009 08:43 AM
ORIGINAL: pmillerusa
...I measured the bore and stroke and came up with .89cu" (so a 90?).
Paul,
Fox never made an Eagle .90 engine...
How are you making your displacement calculations?
The right way is to measure the bore and divide it by two. Multiply the result by itself (square) and then to multiply it by π (Pi - 3.14159...) and again to multiply the result by the stroke (the movement of the piston from BDC to TDC - NOT the depth of the piston in the bore, when it is at BDC).
If, for example, an engine has a 1" bore and a 1" stroke... half of 1" is 0.5". Square that and you get 0.25". Multiply that by π and you get 0.7854", which when multiplied by a stroke dimension of 1", equals to a displacement of .7854 cubic inches...
The Fox .74 has a displacement of .736 cubic inches.
Sport_Pilot 02-02-2009 10:02 AM
I think he did make a .90 or maybe larger. But I think it was a special built engine made for a governement drone, it may have been gas ignition as well.
DarZeelon 02-02-2009 10:17 AM
ORIGINAL: Sport_Pilot
I think he did make a .90, or maybe larger. But I think it was a special built engine made for a government drone, it may have been gas ignition as well.
Hugh,
But it was not an Eagle .90, which was never offered by Duke, or by the factory after he passed on.
Fox do offer larger spark ignition engines.
The photos Paul posted are no doubt of a Fox Eagle engine.
Hobbsy 02-02-2009 10:23 AM
The bore and stroke for the .60 is .905 bore and .937 stroke, the bore and stroke for a .74 is 1.00 bore and .937 stroke. That appears to be an early .60.
pmillerusa 02-02-2009 12:33 PM
Thanks all.
See my last post on the measurements and how I blew the calculations. Doing it right came up with ~.53
Picking up my Micrometer and Calipers from the brother in-law that borrowed them a while back tonight and will re-measure, but with a machinist ruler it’s .88” bore and stroke.
I spoke with Charles at Fox this morning and am sending him these photo's as well as these #’s and we’ll see what they come up with. He seemed to think it was an old .60 as well based on my descriptions.
pmillerusa 02-03-2009 10:22 AM
So when you get the right tools, the job is alot easier... got my calipers back last night and confirmed the .60" size.
Bore .905", stroke .937" ring thickness .046"
Frank said he has the ring for $13.00 and I'll be following up with Charles at FOX later to get details on bearings or if they have a package "overhaul" deal...
thanks again for all the help.
What's the fun in a $99 Magnum when I can overhaul this american iron...? :D
w8ye 02-03-2009 10:41 AM
Your engine uses a 6903 bearing in the rear which is $4.97 from RC Bearings
and it uses a R6-2RS in the front which is $3.97 from RC bearings
That is $9.94 plus shipping from RC Bearings
http://www.rc-bearings.com/catalog/a...b43f&x=11&y=10
http://www.rc-bearings.com/catalog/a...590112&x=8&y=4
both bearings from Boca Bearings come as a set #ENK-40 for $21.95 including shipping
http://www.bocabearings.com/main1.as...054&n=*ENK-040
