RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Counter rotating engines?? (https://www.rcuniverse.com/forum/glow-engines-114/8718052-counter-rotating-engines.html)
moodier 04-26-2009 10:54 PM
Hi;Anyone know if there are any of these left in the world?Have couple of old small frame fox 40s that are sure nice in the Dualist!!Like the way they operate in it but don't think there are any avaiable anymore??Any hints!Thanks!!
w8ye 04-26-2009 11:27 PM
RE: Counter rotating engines??
I think Enya still sells some lefties
The Enya four stroke is reversible by swapping the cams
The Enya SS series two strokes are reversible by turning the front bearing housing 90 degrees to the right when standing behind the engine
Any of the old two strokes with a separate front bearing housings are reversible by rotating the front housing 90 degrees
Some Saitos are reversible by buying a certain cam intended for the rear cylinder of the inline twins
CustomPC 04-27-2009 05:44 AM
Yep,
Enya still make matched "twin sets".
http://www.enya-engine.com/ReverseEngineList_E.html
Ram Jet 04-27-2009 06:19 AM
ORIGINAL: w8ye
I had read this before but thank you for the confirmation. I also think you can have some fun with Enyas by playing with advanceing and retarding the cams. Increase/decrease valve overlap. Now, I just have to figure out how to save your post to my hard drive.
Regards,
Bill
Bone 04-27-2009 07:34 AM
Ramjet - I've just sent you a PM with a copy of the post attached. Now you can save it to your hard drive [8D]
richg99 04-27-2009 01:43 PM
re saving what someone posted. I just highlight whatever I want to save...hit CONTROL C to copy it ....then I open an email to myself...put the cursor in the message box and hit CONTROL V to paste the message. I give it a title that I can recognize and send it to myself.. That way.. I have dozens of R-C KEEP items in a folder on my email page.
regards, Rich
WhiteRook 04-27-2009 03:45 PM
8Y, CAN YOU do it with supertigre 2500 and 4500? front housings
w8ye 04-27-2009 04:00 PM
The 4500 has a rear intake
It could be timed by turning the back plate to the right 90 degrees but the piston will hit the back plate?
There shouldn't be any problem with the 2000, 2500, & 3000
Phoenixangel 04-27-2009 06:09 PM
I have a mecoa .46 2 stroke airplane engine on an airboat that runs backwards, I have no idea if it was ever supposed to or not but it does just fine. Has for months and months.
