Run Time
Due to space limitations, I can only use a 6 ounce tank for a .46. I have never run this small of a tank on this size engine. Without setting up a test stand, what might my run time be at full throttle?
RE: Run Time
maybe like 8 minutes
RE: Run Time
i run 6oz tanks on my proflies, they last quite a while (i can putt around and it will last more than 30 min) on a .40 os gpa and about 25 min on a ax55 flying just above idle
i have a 8oz tank with a gms.47, i add just under a half tank after about 8min of imac flying (most of the time above .5 throttle) you should be fine |
RE: Run Time
I had a plane with a 6 oz tank and a Enya SS40BB engine. On the ground at WOT it would run 7 min
In flight at partial throttle I had no problem flying for 10 min. |
RE: Run Time
Thanks.
I think with throttle management a 20 min flight should be just fine. Tanks again!!!!!! |
RE: Run Time
I have an Evolution .46NT that would probably run 10 minutes on 6 oz. with 15% and an 11x7.
RE: Run Time
Drop the nitro content to 5%, readjust the needles and it should run a bit longer with a bit less power.
RE: Run Time
I thought the rule of thumb was 1oz per minute per cubic inch @ WOT.
David |
| All times are GMT -8. The time now is 07:58 AM. |
