starters
Does any one have a wireing diagram of a 24 volt starter motor using a solenoid????
RE: starters
1 Attachment(s)
This one has a switch
RE: starters
I don't know of anyone using solenoid starters on RC aircraft. Solenoids are used on automobile starters to move a gear to engage the starter motor gear to the engine flywheel.
RE: starters
Solenoids are used in automobiles so you don't have to run a 6 gauge wire to an ignition switch/key. There are usually two of them...one to engage the starter pinion, and the other to activate the first
How come you want to use a solenoid? |
RE: starters
I have a 24 volt starter motor. with 24v. the switch fuses together.
I use two 12 v. batteries, one activates the solenoid and both batteries (24v) runs the starter moter. This method allows me to start all my engines .60, 914c, 1204c, and my Quadra 40. I am going to make some diagrams and some pictures later my e_mail is [email protected] |
RE: starters
This push button switch is rated 40A at 24V $12.99
http://www.jegs.com/i/Mr.%20Gasket/7...0002/-1?CT=999 |
RE: starters
A friend was using a Big Hobbico starter on 24V on his Saito 220 and it welded the original switch contacts shut.
RE: starters
Tell him to e-mail me and i will send him a diagram that will help him out.
[email protected] |
Hello flyers--I have a new Sullivan Dynatron .What is the best battery to use?? I have 2-12volt 7 amp batterys. I want to start engines grom os 120 up to 55 dle gas. What should I use ??? Thanks Chuck
LiPo batteries are lighter. 2 cell LiPos are 7.4v, or a single 4-cell (14.8v) would do the trick and weigh a LOT less than two 12v7A lead acid or lead calcium batteries.
The gear reduction starter the fellow sells on RCU for $140.00 is a good buy, brought one and replaced the 11.1 lipo with a 14.8 and it cranks my 180 Saito fine
1 Attachment(s)
Chuck- I went through the same thing like you are. This is the best answer that SrTelemaster150 sent us:
http://www.rcuniverse.com/forum/atta...mentid=2047529 The Sears price is about $60 which means this is a sale item. I paid that for my 650 amp and this one is the 950 amp. You use a/c to recharge it. It weighs half of what a lawn & garden battery does. And it turns the Dynatron over like you wouldn't believe. It's loafing when it turns over my Saito 125. No more lugging around batteries for me, and I can use it for jump starting cars, lawn mowers, etc too. |
| All times are GMT -8. The time now is 10:12 AM. |
