Well, I'm Ready For The Glory Days Vintage Flyin
RE: Well, I'm Ready For The Glory Days Vintage Flyin
Hi Zor,
I have a number of tube type Citizen-ship radios operating. To solve the HV problem, I have been successful at hacking mobile inverters (the type that plug into the cigarette lighter and provide 120VAC) into HV DC power supplies for the B batteries. These inverters often go on sale for $9.95 and when you remove the case the resulting module is small and when combined with a 9 AA cell (1000mah) battery pack, is actually smaller than the original two 67.5V batteries.
I get about 3 hours of flight time per charge with the power supply putting out 140VDC at 1.2 watts.
If anyone is interested in the details, let me know and I will write up some instructions.
Orv.
Orv.
Banned
ggeezer,
To thank you for the response and your very good solution to replace unavailable B batteries.
DAN REISS is also interested.
In my early days building home brew transmitters and receivers with vacuum tubes I used components from old car radios and built vibrator types power supplies operating on a car battery.
I used VR105 and VR150 to stabilize the high voltage.
Pictures have been posted a long time ago.
I can post some again here in this thread if someone wishes.
I also experimented with a dynamotor from a 19 set which I still have.
For those who wonter the 19 set was used in world war II in army tanks and operated using a dynamotor supplying 250 and 500 volts DC.
These were the good old days .
Zor
