Controlaie Mule single channel
LA
Help
I;m looking for the paper work on this unit.I need to know how to wire it up for a Galloping Ghost actuator.
It is one of the units that was converted to Galloping Ghost.
I rewired it and got the escapement working.Thanks
RE: Controlaie Mule single channel
Well, the Mule was often noted as being the name for the transmitter. I think there were three different receivers which came with this one. The Controllaire 4, Controllaire 5 and the SH-100. There are with and without tube types. Which do you have?
Wm.
Wm.
My Feedback: (18)
Duster, are you talking about the transmitter. They did make a conversion to make the single channel transmitter into a single channel pulser unit. Most guys put the control stick on the top of the transmitter. It was a add on that included a additional oscillator for the pulse generation. The receiver had either the relayless SH100 or had a twin transistor setup on a small PC board for the actuator operation.
Bob Harris
Early RC Models
www.earlyrcmodels.com
Bob Harris
Early RC Models
LA
Hi
There is no cover on the reciever it has no relay it looks to be all transistor. I have it working the escapement now,but when you turn the G/G on it will pulse the escapement, I also have a G/G actuator but I need a wiring digaram to wire it up.
Thanks Glenn
Thanks Glenn
