WACO YMF
RE: WACO YMF
Reyn3545,
I don't have my plans in front of me but I was wondering if the cowl molds you have are for the 1/5 or 1/6 scale Waco's?
Chris
WB #133
Chris
WB #133
RE: WACO YMF
ORIGINAL: Cricklewood
Reyn3545,
Chris
WB #133
Reyn3545,
Chris
WB #133
Sorry, should have said... this mold set is for a 1/4 scale Waco.
RE: WACO YMF
Hey, while I'm thinking about it... for all of you more experienced scale pilots....
When I taxi out for takeoff, I try to feather in the throttle, but I guess I need to do it even slower. Regardless, not long after the tail gets airborne, this plane wants to take a HARD left. My immediate reaction on my 3 flights so far has been to go full throttle, hit the elevator and get away from trouble ( the ground). Luckily, the plane has enough power to get off the ground very quickly.
I'm afraid to put too much rudder correction in it, because I don't want to turn back into the pits, but I do realize the next time the wind shifts and we reverse the pattern, the plane's going to be taking a hard left right into the pits anyway.
I usually take off and land on low rates, with maybe 20 degrees or so of rudder throw in both directions... It doesn't look like that's going to be enough to keep the plane straight at low speeds. How much rudder do you guys have for takeoff corrections?
RE: WACO YMF
reyn,
Having not flown my Waco yet I can't say for sure. My 1/4 Cub takes alot of right rudder to keep her straight until the speed builds. The Waco has alot of plane aft of the landing gear like a cub and will require alot of rudder. I have my Cub setup with full rudder deflection at all times. I have been flying R/C Cubs for 20 yrs and have become accustomed to using rudder and really don't put that much thought into it just do it. Increasing the throttle slower will help but you need to watch and not lift off before you get enough speed. A sudden burst of power after the wheels break ground and she may snap. I input alot of rudder and gradually relax the rudder as speed builds. A little practice at this and it becomes 2nd nature before too long.
Later!!
Anthony
Later!!
Anthony
My Feedback: (28)
RE: WACO YMF
ORIGINAL: reyn3545
Speaking of cowls... I have a set of 3-piece fiberglass molds for a 10 1/2 inch Waco cowl. If anyone is interested in building their own ... you can have the molds, just pay for shipping. It's the cowl with 7 pairs of bubbles.
reyn3545,
If you still have the molds, I'll take them...let me know how much shipping will be and I'll send you a PayPal or Money Order.
Ship them (if they're still available) to:
George Waldrop
250. N. Pebble Creek Terrace Apt #103
Mustang, OK 73064
Thanks in advance!
RE: WACO YMF
OK... they're yours. I'm traveling for the rest of the week, but will try to get them out early next week. I'll let you know what the shipping charges are and when they go out.
I just want to make sure that they go somewhere that they can be used. I don't have a use for them, but I knew someone on here would. Good luck!
My Feedback: (28)
RE: WACO YMF
reyn3545,
Thanks! No rush whatsoever...I appreciate the molds, and will put them to good (I hope...good may be in the eye of the beholder I guess!) use. Just let me know.
RE: WACO YMF
reyn, George, and all,
The Nick Ziroli plans site has the instructions for their semi kit for a 7 cylinder Continental engine using Williams Bros Cylinders that looks very convincing, much better than any vacuumed formed engines. I don't see any problem scaling the same instructions down for the 1/6th or 1/5th; you just have to build the crankcase instead of using NZPs vacuumed formed crankcase.
Site - http://www.ziroliplans.com/zirolipla..._frameset.html or from the home page look under scale items or the link for the 87" Stearman.
My Feedback: (19)
RE: WACO YMF
ORIGINAL: Stickbuilder
20% rudder is not enough. On high rates, you want all you can get, and on low rates, about 75% of that.
Bill, Waco Brother #1
Bill is absolutely right. The engine and cowl eat up a TON of the airflow on the Waco, so the lower rates on the rudder (and on my Waco I found also the lower rates on my elevator) are not effective enough.
~ Jim ~
RE: WACO YMF
All,
There is still time to check out the eBay add for a 1/6th scale Pica YMF kit item # 180470746180 , http://cgi.ebay.com/NIB-RARE-PICA-WA...item2a04e50c44 . Current bid is $127, bidding ends on the 24th of Feb.
Also a 1/6th Dave Platt YMF kit item # 120532867244 , http://cgi.ebay.com/NEW-DAVE-PLATT-M...item1c105198ac , Current bid $35, Bidding ends 28 Feb.
RE: WACO YMF
ORIGINAL: gunner3
Hey Bill, how can I get one of those t-shirts?
Bob: Waco brother #160
Bob,
Contact Mitch (nineonine). Someone bought up some extras and they will probably willingly part with them. Otherwise we'll have to start working on a new order.
RE: WACO YMF
Anyone wishing to get shirts from the original order must contact TexasSkyPilot as he has the only extras. They may be all sold out. We need a guarantee of 75 shirts in order to place a new order from the printer. Mitch WB100
RE: WACO YMF
ORIGINAL: nine o nine
And Here we go again. Mitch, if you do get enough for a second run, they need to stay the same color. Gen. 1 were all tan. Gen. 2 are maroon, we have not decided on what Gen.3 will be.
RE: WACO YMF
Well, I finally got the ailerons temporarily hooked up (Pica 1/5) and was trying to set up the throws when I noticed that the upper ailerons had quite a bit more deflection ( almost double at full throw) then the lower ones. I did not see this addressed in the instructions. Is this a problem? If it is, how do I correct it and if it isn't, which aileron do I set at the 1/2" deflection that the instructions call for? It looks like a geometry issue.
RE: WACO YMF
ORIGINAL: gunner3
Well, I finally got the ailerons temporarily hooked up (Pica 1/5) and was trying to set up the throws when I noticed that the upper ailerons had quite a bit more deflection ( almost double at full throw) then the lower ones. I did not see this addressed in the instructions. Is this a problem? If it is, how do I correct it and if it isn't, which aileron do I set at the 1/2'' deflection that the instructions call for? It looks like a geometry issue.
RE: WACO YMF
gunner3,
The Full size has the slave rod attatched to the lower aileron in board of the trailing edge (fat end of the mount forward) and the upper with the mount reversed (fat end to the rear). The toggle bolt leafs are close copies of the full size mount.
P1 - Lower
P2 - Upper
P1 - Lower
P2 - Upper
RE: WACO YMF
Thanks John, that makes sense, but it doesn't answer my question. Can I live with this or do I need to do surgery to my connecting rods and my ailerons?
Bob: Waco brother # 160
RE: WACO YMF
Dang it! I said it bass ackward. Yes you need to correct the setup. The link does not maintain the plane of the Interplane struts. It leans a little toward the trailing edge at the top. John, thanks for catching my screw up.
RE: WACO YMF
Hey all,
Just wanted to introduce myself. I have been lurking around here for the past couple of weeks. I recently picked up an original 1/6 Pica kit that is partially built from an estate sale, and am looking forward to getting started on it. After watching the auction last night on E-bay I am happy with the price I picked mine up at. (nearly half). Just wanted to say that everyones projects look great and I will be pleased if mine come out half as well.
I was thinking of putting a 91 Magnum 4 stroke in my Waco, is that too much engine for this plane?
Red.
Red.
