Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 07-08-2014, 04:16 AM
  #17551
ceije
Cougar, for flying wires try Aero Scale I believe at aeroscale.com, they are rather expensive but they are scale. they're located in Switzerland
chris melhus,ceije 196
Old 07-08-2014, 05:50 AM
  #17552
acerc
acerc's Avatar
Originally Posted by Zor
You flying wires look nice but they are not installed to prevent the wings from folding up on a high G lift.
Zor
And you know this because, you built the plane, you custom made the hardware, you installed the custom mounting hardware, you have tested the hardware. How in the hades can you possibly know they do not hold anything???
Old 07-08-2014, 06:33 AM
  #17553
ceije
Robert isn't Zor the person Bill requested about a year ago to stay out of the forum due to his disruptions????
Chris Melhus, CEIJE #196
Old 07-08-2014, 06:38 AM
  #17554
Zor
Banned
Originally Posted by Cougar429
One question for the forum. Now that I'm confident nothing major needs to be changed, looking at adding flying wires. Need to be relatively quick to assemble/disassemble at the field.
Anyone have any ideas? Pics would be nice.
Hello Cougar429,
You can use snaps. The kind and size used on winter jackets.
Install them so that the tension force in the flying wires works along the face of the snaps ( not trying to unsnap them ).
You snap them on by hand or with long nose pliers and unsnap them with a 3/16" or 1/4" flat screwdriver.
One end of the flying wires can be attached permanently and remain with the fuselage ( snaps at the wing struts ) or with the wings as the wings are removed ( snaps at the fuselage ).
I can make you a skektch if you need.
Regards from Zor near Toronto.
Old 07-08-2014, 06:53 AM
  #17555
acerc
acerc's Avatar
Many have on many a thread. But he just seems to get a thrill out of throwing idiotic statements around like he knows something we do not. Such as my flying wire's not withstanding force, but yet, he says to use snaps. ROTFLMAO
Old 07-08-2014, 06:56 AM
  #17556
Zor
Banned
Hi acerc,
I am being friendly with you.
Yes ... I built a biplane, a Super Skyolt and I made some custom made small fixtures and installed tensioning hardware on all ten wires. I did test the results and the design is such that the wings cannot fold up.
My comment was based on what I see in your posted picture.
Regards from Zor.
Old 07-08-2014, 07:01 AM
  #17557
acerc
acerc's Avatar
Hi acerc,
Regards from Zor.
You should refrain from comment when you don't know what you are talking about. When you don't know you should ask before giving advice. But most of us know you better than that. This is the last I will speak with you.
Old 07-08-2014, 07:06 AM
  #17558
Zor
Banned
Robert,
Isn't Zor the person Bill requested about a year ago to stay out of the forum due to his disruptions????
If you wish to consider helping someone is a disruption . . . .that is your privilege.
I am trying to be friendly with you also.
Zor
Old 07-08-2014, 07:21 AM
  #17559
acerc
acerc's Avatar
ceije, if this is the place you are referring to, http://www.flying-wires.ch/flying-wires/index.html, I got some from them for my big Pitts. They were not that expensive to me, around $300, but the wing wires were near 4' long.
Old 07-08-2014, 09:09 AM
  #17560
Zor
Banned
Dear acerc,
That is fine with me.
My comments were about a technological subject _ _ _ not about you as a fine person.
On my C-IKOS the lower ends of the flying wires are attached to a dural aluminum plate going across the bottom of the fuselage under the 1/4" hard five ply landing gear mount and just ahead of the landing gear.
The landing gear can be removed or brake off (in a real hard landing) without affecting the flying wire installation. Also both wings can be removed without affecting the flying wires installation. They stay with the fuselage and the interwings struts.
So I do not know what I am talking about. In your picture the lower end of the wires are apparently attached to the low wing root. You did not explain if there is any strong component joining the two sides. It appears to me that the low wing attachment to the fuselage is not protected by the flying wires. If you disconnect the lower end of the wires it makes no change to the strength of the wings at the fuselage.
If your picture is illustrative, I would not encourage builders to build per that illustration.
You do not have to talk to me but you may reconsider some of your writings and again tell the average reader about Zor.
More pictures are available showing the installation on C-IKOS.
Best regards,
Zor
Name:	R 100_7177.jpg
ID:	2012608   Click image for larger version
Name:	R 100_7178.jpg
Old 07-08-2014, 11:50 AM
  #17561
ceije
Robert, yes that is the site i was thinking of, thanks forth correction to the web site,
ceije 196
Old 07-08-2014, 12:51 PM
  #17562
LesUyeda
Banned
"Your flying wires look nice but they are not installed to prevent the wings from folding up on a high G lift. "
Out of scientific curiosity, what is it that you see, that I don't, that prompts you to come to that conclusion????
Les
Old 07-08-2014, 01:33 PM
  #17563
Zor
Banned
acerc.
I am glad to read that some of my postings are making you Roll On The Floor Making AO .
I never wrote that your flying wires are not withstanding force. It is a matter of where the flying wire tension is applied to strengthen the G force exerted on the wings.
A model airplane can easilly be subjected to 20 and even 30 Gs while maneuvering in flight. That was written by someone else and I believe it.
Using snaps is a very convenient way of quickly installing struts or removing them at the flying field.
Of course they are not scale details but they can be installed that they are barely noticeable.
They are installed permanently and avoid the risks of loosing small screws, small nuts or small cutter pins in the grass and the time of installation. I used them on four models ( of which three have been given away to friends when I moved ).
I still have one model with snaps on the struts.
It is not as crazy as you seem to think.
Enjoy,
Zor
Old 07-08-2014, 01:59 PM
  #17564
Zor
Banned
Les
Hello Les,
What I see is that the lower ends of the flying wires at the top of the lower wing near the fuselage seem to be attached to the spar(s) at a rib outside of the fuselage.
If it is so as seen in the picture attached to post #17545 then they do not reinforce the wings. The wires could be removed and the model would still have the same wing strength. To be effective the flying wires going from the underside of the top wings near the tips ( or interwing struts ) have to go to the fuselage structure such that the wire tension under high G force goes from one wing tip to the other wing tip.
Same applies to the set of wires upon a hard landing or under inverted flying.
Nice to read you Les.
Zor
Old 07-08-2014, 02:58 PM
  #17565
acerc
acerc's Avatar
To my fellow Waco brothers:
Please do not respond to the previous subscriber, it will never end if you do.
Old 07-08-2014, 03:21 PM
  #17566
hopkimf
My Feedback: (56)
I've been reading this discussion since I am about to set up the wires on Barth 1/3 YMF. I don't have a choice if I build per plan because kit designer located anchors. The wires from upper wing outer to lower wing at fuse both effectively attach to fuselage. The front wire attaches to a stud that is bolted into fuse. The rear pair of wires attach to wing center section which is integral to fuse. It would be interesting to see a couple free body diagrams with two assumed wing loadings that would show wire loads.
I do have a concern with my kit. It's one of the original offered by Barth some years ago. The full scale Waco had a pair wires on the rear and a single on front. Must have been needed. On my plane the rear pair are anchored by one 4-40 screw with a two ear bracket. The front is anchored by a 1/4 stud. I am worried about the rear one failing, but don't have any good ideas about beefing up the anchor. If anyone else has given this any thought, I would appreciate comments.
Mike Hopkins
WB #132
Old 07-08-2014, 04:16 PM
  #17567
Stickbuilder
Stickbuilder's Avatar
Zor, I asked you to leave this page over a year ago. If you make another post on this thread, I will ask the Administrator to remove you from RCU. Got it? Get it!
Bill, Waco Brother #1
Old 07-08-2014, 07:05 PM
  #17568
tmac48
tmac48's Avatar
Mike I believe Peter Barth lost his own model with this anchor attachment and subsequently changed the instructions and all later kits went with two screws , I changed this and went with two eye screws. Peter has seen my instillations and has stated his concern that they may not be substantial but I am convinced that my anchorage is as good as if not more substantial than what was asked for in instructions. Peter Barth is no ordinary modeller and I would have full confidence in his recommendations on this matter.
tmac48
ID:	2012734   Click image for larger version
ID:	2012735   Click image for larger version
Old 07-09-2014, 02:07 PM
  #17569
Cougar429
Cougar429's Avatar
tmac48, looks beautiful, but may not be the best for something on my scale, nor easy to work with repeatedly at the field, (want something quick, easy and reliable). Still, can you take some closeups of the attach points at the fuse?
Old 07-09-2014, 02:22 PM
  #17570
acerc
acerc's Avatar
Cougar, if you really want the best of appearance and relatively easy in and out you have got to check out http://www.flying-wires.ch/flying-wires/index.html. I paid around $300 for my 46% Pitts, ws of 96 inches.
Old 07-09-2014, 09:39 PM
  #17571
tmac48
tmac48's Avatar
Couger will have a go at some close ups but not that good of a photographer. The ends with the pins and cotter pins attach to the fuselage and stay there. The other ends attach with the bolt and nuts that attach the struts to the wings, after the initial set up the flying and landing wires do not need to be adjusted again. Hope this makes some sense.( The flying and landing wires stay with the fuselage when the plane is disassembled.) THIS SITE WILL NOT LET ME DOWNLOAD PICTURES!!!!
tmac
Old 07-09-2014, 09:43 PM
  #17572
tmac48
tmac48's Avatar
Default photos
here u go.
ID:	2012945   Click image for larger version
ID:	2012946   Click image for larger version
ID:	2012947   Click image for larger version
Old 07-10-2014, 11:45 AM
  #17573
mrdhud
My Feedback: (48)
mrdhud's Avatar
Hello all,
Stopped by Mason's today to have a look at the Waco the clear cote has been sprayed on and it looks fantastic. The decals on the cowl went on well with a little heat not perfect but dang good.
I'll post some pictures from my phone.
Old 07-10-2014, 11:49 AM
  #17574
mrdhud
My Feedback: (48)
mrdhud's Avatar
Old 07-10-2014, 11:51 AM
  #17575
mrdhud
My Feedback: (48)
mrdhud's Avatar
can only post one pic at a time on phone
