Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 10-02-2016, 09:18 PM
  #18851
aminiet
aminiet's Avatar
Nice
Old 10-03-2016, 05:30 AM
  #18852
Stickbuilder
Stickbuilder's Avatar
Dan, someone in the family may have some. Grandfather passed on in 1955 and his planes were sold. I was 11 years old at the time and was not happy that they were selling his planes. A few years later I traded a motorcycle for a J3 Cub that I wound up flying from his grass strip. Somewhere there is a photo of me with the Cub. I haven't seen it in 50 or so years.
Bill, Waco Brother #1
Old 10-05-2016, 04:24 AM
  #18853
Jaybird
Great Planes WACO at KVMA.
Jaybird
ID:	2184532   Click image for larger version
ID:	2184533   Click image for larger version
ID:	2184534   Click image for larger version
ID:	2184535   Click image for larger version
ID:	2184536   Click image for larger version
Old 10-06-2016, 07:25 AM
  #18854
Ekim
Glad this thread is still here. About 6 years ago, for too many reasons to go into, I had to put my Barth 1/4 scale project aside. Now I'm just getting back into it and all of the things that puzzled me then are starting to come back. As the photo shows, I have all the main components built. Peter calls for the stab to be adjustable but I just don't like this idea. It doesn't seem strong enough. The TE of the stab is only held down with two lite-ply yokes at the end of the fuse. This is the stab pivot point. The front of the stab is only held in place by a 5M nylon adjustment bolt. This leaves only the wire struts to give it any stability. He calls for a +2 deg. AoA for the stab. My instincts tell me to just glue it in at the recommended + 2 deg. and forget this adjustment idea. Any thoughts?
Mike Linderman
Old 10-06-2016, 11:13 AM
  #18855
mrdhud
My Feedback: (48)
mrdhud's Avatar
Mike Linderman
Mike glad to see you back to the build. Not sure what to say about the adjustable stab hopefully some one else will jump in with ideas.
Old 10-06-2016, 11:15 AM
  #18856
mrdhud
My Feedback: (48)
mrdhud's Avatar
Jaybird
Jaybird I have one of the GP Waco's good flying plane.
Old 10-06-2016, 02:41 PM
  #18857
tmac48
tmac48's Avatar
Ekim I have built the Barth 1/3 scale kit and decided against having the stab adjustable but I am very glad that the way that I did build it that it was easy to alter the AOA of the stab because I have adjusted it to what appears to be more like 4-5deg of positive attack. In retrospect I would trust Peter Barth's instructions and build it the way he suggests. What ever you decide to do I would at least give thought to the fact that you will most likely need to adjust it after the first flight!.
Regards tmac48
ID:	2184671   Click image for larger version
Old 10-07-2016, 07:19 AM
  #18858
Ekim
Thanks, Dan. Tmac has an interesting idea.
Old 10-07-2016, 07:42 AM
  #18859
Ekim
Thanks tmac48. Ingenious idea. I have a BUSA Nieuport 28 that I wish I could alter the stab. Your larger scale afforded you some workable space for your idea but I think I can do something similar with this 1/4 scale. Thanks for the suggestion & photos.
Old 10-07-2016, 04:12 PM
  #18860
tmac48
tmac48's Avatar
Ekim, glade to be of help. The correct incidence of the wings and tailplane and the COG (start nose heavy- a pig to land if tail heavy) pay attention to all of these and you will find her a ***** cat to fly. I did not use any down or right thrust but that was only my decision so as to fit the 150 twin in the cowl. With rudder on take-off I have no problems, but will most likely add 2deg of right thrust when installing the Moki 250, but once again I do not think that this is something that is a must as long as you are ready to get on the rudder to counter the torque of the big props.
Regards tmac48
( The term for a baby cat must relate to something different the USA!!!)
Old 10-08-2016, 05:44 AM
  #18861
Ekim
Wow! A Moki 250! Such a sweet motor. I'll be using either a G-62 or a DA-50 in this 1/4 scale just because I happen to have both. A radial would be nice but I'm not sure my 10" cowl would handle it, not to mention my bank account.
Ha! Loved your comment about what to call a baby cat. Until this crazy election is over I think I'll play it safe and just say "kitten"
Thanks for the advice.
Old 10-13-2016, 04:53 AM
  #18862
ceije
Mike, I have the same bird on the table not quite as far along as you are and its been about the same time frame also. I tried several ways for the adjustment including Bill modification and went back to the plans setup, had the same feeling about the mods. and feel very shakey about the Barth design. I'm inclined do the same as you- hard mount in place at+2 deg. and go from there.
regards Ceije, Chris Melhus
Old 10-13-2016, 07:53 AM
  #18863
Ekim
Hey Chris,
Thanks for commenting. I was hoping you would. I knew there was someone from a ways back that was building the Barth 1/4 YMF. Now I remember your name.
I like the idea of an adjustable stab and I've spent a lot of time trying to come up with a solution that I like, including Peter's design. There's just not enough stability to suit me. I'm just going to permanently mount it at his recommended +2 deg and move ahead.
Maybe I have a phobia about unstable stablizers��.
Thanks again.
(I'm open to any helpful suggestions. Even unhelpful suggestions)
Old 10-17-2016, 09:41 AM
  #18864
kvlasblom
kvlasblom's Avatar
Hi all,
I'm sure that some of you have included the scale feature of the rough area on top of the lower wing that one may walk on to enter the cockpit. Sorry, I don't know what this is called...
Anyway, I was wondering if anyone could advise me on how to model this on my 1/6th scale SRE (http://www.rcuniverse.com/forum/rc-s...c-plans-9.html).
Any tips are welcome, but bear in mind that I will be spraying the surface and have in fact already covered the wing with Oratex and sprayed this the base colour, having overlooked this feature slightly.
Thanks!
Kim
Old 10-17-2016, 10:32 AM
  #18865
aminiet
aminiet's Avatar
For your walkway, I used gloss black paint and sprinkled white sugar lightly.
Old 10-17-2016, 12:03 PM
  #18866
tih
Isn't there a special textured paint people use for the black surfaces inside cockpits? That might be good for walkways, too.
Alternatively, I've seen a 1:7 scale model with a strip of fine, black sandpaper (the kind meant to be used wet) glued on. Looked good, but was obviously too thick when you touched it.
Old 10-18-2016, 06:56 PM
  #18867
ctflyboy
Dan (mrdhud)
My Father-in-law- (may he RIP) once said to me "George if it wasn't for bad luck,I'd have no luck at all" well I guess that holds pretty true so with that said. In my shop working on my Waco, don't know how it happened but it did flipping the fuselage over, lost my footing slipping (prosthetic leg) drop the fuselage it hits ends of the rolling table knocks the vertical fin completely off, breaks the stab where it glues on to the rear of the fuse and that takes a large bit of wood where it glues on. And to think I was almost done, so removed the covering got most of the repairs done. I think I'll take a break from it.
Old 10-19-2016, 02:31 AM
  #18868
Cougar429
Cougar429's Avatar
Oh man! Can I relate. Some days from the moment I wake up cannot count the number of things dropped and retrieved, only to be dropped again!
As long as you're O/K and the plane is salvageable guess things are better than they could be.
Old 10-19-2016, 01:18 PM
  #18869
kvlasblom
kvlasblom's Avatar
Thanks everyone. I will try paint with some microballoons on a piece of scrap and see how that turns out.
Sorry to hear that George! I have to say my models suffer more damage inside the house than in the field.
I once had a friend that had a wing ready for covering, stood against a wall with the root rib on the floor. Then his pet cat used it as a ladder, damaging every rib on the way up...
Old 10-22-2016, 03:40 PM
  #18870
mrdhud
My Feedback: (48)
mrdhud's Avatar
Originally Posted by ctflyboy
Dan (mrdhud)
O man George I hate to hear that. As long as your OK I know you can do the repairs after your break.
Old 11-03-2016, 07:43 PM
  #18871
mrdhud
My Feedback: (48)
mrdhud's Avatar
Just wanted to say hello to all hope your flying days are good.
Old 11-12-2016, 06:03 AM
  #18872
astrohog
astrohog's Avatar
Anybody looking for a NIB Pica 1/5 scale WACO kit? I have one that has only been opened to inspect contents (wood is still packed as tight as it came from the factory). I will not be building it any time soon as I have moved into larger models, so I have decided to make it available to those here that are so passionate about this model.
PM me if you are interested in making an offer on this beautiful kit!
Regards,
Astro
Old 11-18-2016, 07:57 AM
  #18873
dwmcmike
Default 1/5 Kit with FG Cowl and Pants, Health forces sale
I really hate to do this, but I've come to the realization that I won't be able to build this kit. I've wanted one for so long, and finally found a kit, but i'm just not able to put the time and effort into the project that it so deserves.
I'm sure you are all familiar with the kit, so I'll just say that it's NIB, and it's all there (yes, I inventoried it to be sure). And thanks to some sweet talking and the wonderful people at Fibre-Tech n' More, I managed to get a very high quality YMF Cowl (yes, the 'bumps' are correct) and Wheel pants from them. Yes, I paid a premium for the quality, but it is worth it for sure. Very few, if any, pinholes that I can find anywhere on the parts. Definitely superior to stans parts for sure!
I'm asking $350 with the FG parts, $250 for the kit without them, the ABS parts are still safely snuggled in the kit box. I'm just trying to break even on the pricing, not trying to gouge anyone. I will consider any offer if you'd like.
I'll also include a thumb drive with documentation that i've searched out online, including the templates for the formers, ribs, and the scale spar modded wing ribs. I'll also include some drawings and printed media as well.
I'm hoping to take the hobby $$$ from this sale and pick up the ARF version (I know... it turns my stomach too) so at least I can enjoy flying a WACO!
Pics are below! Sorry, attack Chihuahua is not included. PM me for questions, offers, or general comments.
ID:	2190352   Click image for larger version
ID:	2190353   Click image for larger version
ID:	2190354   Click image for larger version
ID:	2190355   Click image for larger version
ID:	2190356   Click image for larger version
ID:	2190357   Click image for larger version
ID:	2190358   Click image for larger version
ID:	2190360   Click image for larger version
ID:	2190361   Click image for larger version
ID:	2190362   Click image for larger version
Old 12-04-2016, 01:59 PM
  #18874
mrdhud
My Feedback: (48)
mrdhud's Avatar
Hello any body home? I've been flying the GP Waco and having ball with it. Mike president of the club was flying it some time back and the cowl, engine and firewall parted ways with the rest of the plane high in the air and he still managed to set it on the ground without as much as bending the landing gear patched her back up good as new.
ID:	2192245   Click image for larger version
ID:	2192246   Click image for larger version
ID:	2192247   Click image for larger version
Old 12-15-2016, 11:20 AM
  #18875
Jim Henley
Wow Dan! Your friend Mike did one heck of a job bringing that air frame down with no damage! I am still chipping away at the AMR 33%, I hope to start covering sometime after the first of the year. Happy Holidays to all!
