KRAFT CHANNEL MASTER INSTRUCTIONS
Hi,
I recently acquired a Kraft channel master tx module and receiver but no instructions,looks pretty simple to use but would like a set of instructions .I f any one has them and can scan them for me It would be appreciated
My Feedback: (99)
NC
RE: KRAFT CHANNEL MASTER INSTRUCTIONS
Good morning,
It has been several years since you were looking for Kraft Channel-Master instructions. Dod you ever find any?
I just picked up a reciever and wonder if there is a key to operation. I did not get the xmitter module but I do have a Kraft FM transmitter whould should make it work but no luck yet.
Craig Journey
919-639-5864
[email protected]
Craig Journey
919-639-5864
[email protected]
i am not sure as I never got any instructions but back when these came out we were only allowed to use even channels and only ch 12 then 38 thru 56.I do not know if any of the odd or in between channels work or if a mod needs to be done to make them work
My Feedback: (99)
NC
Thanks for the info. My FM transmitter is on CH 40. Reciever looks OK, no physical dammage, but won't play!
Thanks you again for the answer!
Craig
Craig
CT
I have used a channel master in the past. It would work JR receiver, so I do not know if that makes it positive or negative type of FM. Also for some reason I could not work the FM Kraft receiver with any transmitter I had irregardless of whether I transmitted in the negative or positive mode, even though the other transmitter would work the above JR receiver.
There were some mods made on the one I used to make it more reliable and it was gold stickered for narrow band. I believe the one I used was updated by Kraft Midwest, I am unsure if they are i
n business. I know Radio South will still service it.
I will look through my stuff and see if I can find the instructions.
My Feedback: (99)
NC
That is good info. I fly both JR and Futaba so I understand this positive vs negative shift stuff. Kraft I had always assumed was the positive shift like Futaba. Your experience would hold that not to be true so let me look at that issue and see wher it goes.
Many thanks again,
Craig Journey DBA
RC Wings and Things
919-639-5864
See my full inventory at:
http://www.swampsrc.org/links.shtml
Many thanks again,
Craig Journey DBA
RC Wings and Things
919-639-5864
FL
As I recall the channel Master channel 40 is blocked out for some reason, may be the way it was designed. Also Kraft had their own way of tuning their transmitters and receivers. Check with Tony at Radio South.
Joe
Joe
My Feedback: (99)
NC
Joe,
You have been a great help! I did find that my JR transmitter worked! It is interesting that the Channel-Master is lower sideband while the standard FM Kraft system on channel 40 is an upper sideband unit. I guess I live and learn!
You do not have the transmitter module for the Channel-Master by any chance? If so would you like to sell it? I am a collector of sorts for the old Kraft stuff and this would complete this set for me.
Craig
Craig
I believe glasair is right about ch 40 blocked in the tx module. I have never had a problem with the channel master and regular Kraft FM rxs. I believe the 72 FMs are positive shift the AMs on 72 are negative shift.
ORIGINAL: CJrc
Many thanks again,
Craig Journey DBA
RC Wings and Things
919-639-5864
Many thanks again,
Craig Journey DBA
RC Wings and Things
919-639-5864
Bruce
ORIGINAL: TFF
Bruce
ORIGINAL: TFF
I thought the Proline receivers were positive shift on AM?
Bruce
Hi i now it could be a slim chance but would some one have a Receiver channel master Lying around in there collection of kraft stuff king regards john[sm=confused.gif]
ORIGINAL: aerowoof
john schicker
contact me via email .
john schicker
