Power House Plans Needed
I am looking for plans for the Sal Taibi's 84" wing span"Power House". I have the kit, but the plans are missing.
Any help appreciated.
Bullio
Bullio
Thank you for the infro. I would like to find someone or somewhere to purchase full size plans,I did not see the wing plan on the web site you gave me. If my request is not possible I will make use of the infro you sent. Thank you again Bullio
My Feedback: (87)
I have a set of plans for the 84in Powerhouse. I got them at Toledo a few years ago. I can't remember who they came from or how much I paid. Might be willing to sell or trade for them. They are new and unused (rolled). Let me know if you are interested.
RSN
RSN
Hi CoosBayLumber,
Check http://members.dcsi.net.au/jtboundy/Pics/SamSearch.htm
and do a search on Powerhouse.
regards,
JVB
regards,
JVB
I have a couple of Northrop plans. He still sells plans at local model A/C shows with both his name on them and that of Model Builder magazine.
Only problem with the couple I have is that the re-draws he does bear little 'semblance of the configuration of the originals. In a few instances the plans have "updated" information also, but it is not consistant. If you want an original looking A/C buy an original plan, but if you want a 'semblance by all means get a re-draw.
Wm.
Wm.
My Feedback: (147)
GA
I recently acquired a built 84" WS Sal Taibi Powerhouse plane in good condition. It had been fitted with an electric motor and I am planning to install an OS 48 FS engine. Need your thoughts on engine combination and balance point for sport flying.
Thanks in advance for your help.
My Feedback: (9)
A OS 48 4-stroke will fly it just great , balance it on the spar would be close. I always flew mine with about a 1/2 to 3/4" washout in wings. The original had beams built into the structure & the engine mounts were two maple short beams that bolted through the first ones & the engine mounted on a plywood plate that bolted down to the second ones , did I lose you yet? Have flown them with up to a 70 4-stroke. Good luck & enjoy . MAX H.
My Feedback: (147)
GA
MaxH,
Thanks for the quick reply. You did not lose me on the motor mounting. My first RC plane was Jack Ports '56 Nats winner "High Q". I built it in '62 with MinX single channel receiver, Bonner escapement and break away motor mount plate.
