Go Back  RCU Forums > RC Airplanes > Golden Age, Vintage & Antique RC
Reload this Page >
Dallaire Sportster questions
Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Old 12-18-2008, 08:09 AM
Strat2003
Default RE: Dallaire Sportster questions
Rebelion, are you familliar with the practice of double gluing, or "sizing"?
On end grain joints, like the uprights in a fuselage, it helps to put a little glue on the end grain, wipe it off and let it set a little bit, then go back, apply glue, and put the part in place. I usually let it set long enough to make the next one or two pieces.
The first application penetrated and seals the end grain and you end up with a much stronger joint.
Old 12-18-2008, 03:52 PM
timfarrar
timfarrar's Avatar
ORIGINAL: Strat2003
Thanks for the tip !!!
I was wondering, is that the way you are suposed to glue spruce ?
Or do most people use epoxy ?
Thanks again, I may give your sugestion a try !!
Seeya, Tim
Old 12-18-2008, 07:13 PM
Rebellion
ORIGINAL: Strat2003
Thanks Strat! I'll give it a try, and use epoxy as well.
Old 12-19-2008, 08:39 AM
Strat2003
I've always had good luck with yellow (aliphatic) glue on spruce and plywood, too. As long as you make good joints the wood will fail before the glue.
Old 12-19-2008, 01:06 PM
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Strat2003
I have used this glue ever since it came out on model airplanes and furniture, and have always been pleased
Old 12-31-2008, 07:17 AM
  #31
timfarrar
timfarrar's Avatar
Hey guy's !!
I am needing to set my engine thrust on my Dallaire so I can make my cowl...
The plan's just show straight ahead !!!
Dont I need about 3 degree's down and 3 degree's right ?
What do you think ?
Seeya, Tim
Old 12-31-2008, 08:27 AM
  #32
Strat2003
My little Speed 400 size Dallaire needs quite a bit of downthrust.....I'm guessing it's about 4 or 5 degrees, so I think 3 degrees would be a good starting point.
Old 01-01-2009, 04:23 AM
  #33
timfarrar
timfarrar's Avatar
ORIGINAL: Strat2003
Thanks Strat2003 !
Your the second to say 3 degrees down !
Seeya, Tim
