Andews Aeromaster help please
1 Attachment(s)
My brother built an Aeromaster in the early 70's. It flew a few times and has spent the last 40 years or so in a few attics. I'd really love to get her in the air, but need some help. I'm not sure I'm pilot enough for it yet.....but hey....it's my big brothers. I can wreck it. :D
Can anyone tell me were the CG is? I was thinking of trying to find a .60. Big enough? My brother used one servo for the ailerons. The setup is goofy and broken. I'd like to put a servo in each wing. How small can I go? The hinges are pinned and seem tight to the tug. Will they be okay? I'm not sure if this is the correct forum, but I appreciate any input you guys can offer. Thanks!! Mike |
RE: Andews Aeromaster help please
Mike, if no one knows, use this website to locate the CG of each wing. Use 30% for the percent MAC. Put the CG for the plane in between the CG for each wing. A 50 ounce/inch servo would be enough for each aileron and if you want to use a servo on each elevator, the 50 ounce one would be OK there too. It would be tough to rehinge the surfaces. If they feel good now give it a try but monitor them closely. It may be necessary eventually. I think it was designed for a .60. Maybe someone else knows. That's a great flying model from the good old days. Getting it airborne again would be a nice accomplishment. Dan.
1 Attachment(s)
With both wings swept back as yours is, you can put the CG as far back as the rear vertical cabane.
The plans call for it to be about a half inch forward of the rear cabane. You can download the plan from here free. http://www.outerzone.co.uk/plan_details.asp?ID=1971 The belcrank system of one servo for both ailerons works well if done correctly. I have one with a Spektrum DS 821 servo driving the two ailerons. Works fine. I also built one with two servos buried in the wing so each aileron had it's own servo. I used Futaba 3004 servos for that. personally, I wouldn't go smaller on the servo, but that is just me. The Aero is pretty fast and the one I built for a friend has an OS 95 in it. I would not have recommended that engine, but after seeing it fly, I'm a believer. it's a good combination. First picture is the one with the two servos buried in the wing. The servos are attached to a 1/16 ply plate and held in with screws. The second picture is the one with belcranks and a single servo. |
Thanks guys! Flew her today. I over controlled her on the runway on the first flight and broke the prop and bent the gear (actaully...it wasn't a "fligt" so much as a really bad taxi and take off attempt).Once I got her figured out and got help she flew great. Really great airplane......
