OS Minitron 12 channel reed
1 Attachment(s)
I came to want to hear the sound of reed.<a href="http://www.youtube.com/watch?v=nZPrqq5mKnc">
http://www.youtube.com/watch?v=nZPrqq5mKnc</a> And I tried to make single channel emulator. |
RE: OS Minitron 12 channel reed
Thank you for posting this, MeowJPN. It brings back many memories. I had never seen an OS reed radio, but it appears to be of very advanced design compared to the reed radios with which I was familiar.
The transmitter is no doubt capable of "simultaneous" operation of some channels. If you wish, you may apply rudder and elevator control at the same. If I am correct, you will hear two reeds vibrating at the same time. The simultaneous sending of two tones has a very unique sound. Dick |
It is good to see your OS Minitron reed system working, well done. I also have an OS Minitron reed system, a 10 channel one. After some recently completed service work I have it fully working. Simultaneous operation of any left side channel with any right side channel should be possible, such as up elevator and rudder together for a spin. After replacing a dead germanium transistor in one of the audio oscillators I have the simultaneous operation working well. As otrcman says you get some distinctive beating sounds from the two different reed frequencies.
Thank you for your reply,otrcman.Sorry I am not good at English.
OS MInitron iswhat a freid of mine got recently.And It will be borrowed for a while. So, >The simultaneous sending of two tones has a very unique sound. I will try it. Thank you! |
Thank you for your reply, ukengineman.Sorry I am not good at English.
>After some recently completed service work I have it fully working. Thts' fine! I was surprised because the one that made by about 50 years ago had moved. >Simultaneous operation of any left side channel with any right side channel should be possible, such as up elevator and rudder together for a spin. "For a spin" ! I understand. A wonderful maneuver was done in that age.Though I have not seen. because I am young....may be... |
1 Attachment(s)
Single Emulate System is this.
My acquaintance actually could good fly by this. |
