Dynaflite Talon T.E. ???
My Feedback: (33)
Wing assembly
first steps show to locate TE stock 5/16 X 1 1/4 X 24
I have two 5/16 X 1 1/4 X 24 but they are not tapered TE as plns show, or is it intended to be that way? Just curious as the plans refer to laying them 90Deg. side down.
Instead of trying to sand the taper I will visit my LHS for a set tomarrow, but wonder if this has been mentioned before or is just a factory error on the way the come?
Thank's
Thank's
My Feedback: (33)
RE: Dynaflite Talon T.E. ???
Thank's for the clarification on this, Bax
EDIT:
I went to the online manual for the Talon
And it clearly shows TE stock to be shaped using a planer & sanding bar. 'as You pointed out'
It seems I have a much older version as my manual and plans both only refer to sanding the STE (sub trailing edge) to match the TE contour and show a profile pic aswell. L7 ?? on plan and in the manual.
If My manual had the mention of the razor plane and marking the TE for desired shape, I would not have posted my above question.
Thank's for the nice feature of the online manuals, Sorry I did'nt check first.
EDIT:
