Top Flight P-51 .60 Gold Edition TailWheel
I am almost new in building and R/C flying (started 18 months ago), but i already have 6 models all kit building.
The P51 from Topflight is really a challenge for me and i ask if it is possible to have a retract tail wheel for it. I chose to build it with the Robart Pneumatic system and struts.
Thanks in advance. Pierre.
RE: Top Flight P-51 .60 Gold Edition TailWheel
OK Bax. What do i need also in order to have the retract work : direct servo connection or an air line connected to the main tank and to another air cylinder ? What is recommended for this kind of plane ?
Thanks for your help. Pierre.
Hello, i am back now on building the fuse of my TF P51. I have my item #121 for the retract tail wheel. I wonder what is the best and secure choice (this is my first "detailed" kit) : either to plumb the tail wheel to the air mecanism for the others wheels, or use a dircet servo ? What is the best weight solution, and where to put the air cylinder in order not to change the CG.
Also if i use the retract tail wheel i will change the metal pushrod for a flexible cable. In this case how do i manage to controle the rudder ? Do i need to use 2 separate pairs of cables, one for the wheel and one for the rudder, connected to the same servo ?
Thanks for any advice you could provide me.
Pierre.
Pierre.
You can't install equipment in the model without "changing the CG". Anything will affect the balance. For the retract, you want the pushrod as short as possible, and make the installation as convenient as possible. Some people have mounted the gear and actuator into a single framework so it could be removed as a unit for maintenance/repairs. That type of installation would be up to you.
Use separate cables for steering the tailwheel retract. You can make a tiller that's mounted aft of the rudder servo, or even use a separate servo that's "Y'd" to the rudder servo, or on a separate channel and mixed to it. The reason you'd want a separate tiller for the tailwheel is to reduce its travel.
