top flight corsair
top flight corsair
I have a question reguarding the landing gear I want to use retracts the problem is I do not have them yet but want to keep on building I have installed the mounting rails and was wondering if its possible to sheet the wing and put them in when I get them
RE: top flight corsair
You would need to remove neccessary material from some of the formers to accept the wheels, that will be much easier if you havn't sheeted the wing.
CA
Just started building the kit, and i am having a hard time finding more detailed instructions for the retracts installation. Does anyone have any info? Thanks for your time
Between the kits building instructions and the retracts' installation instructions, you should have enough information to install the retracts. If you need more general information, a search through RCU with "retracts" as your keyword should bring up a wealth of information.
