Airelons /rudder on TF Gold Edition Spitfire
Please can anyone tell me what or how should I cover the Airelons and Rudder and flaps on a top flite spitfire, should I use sheet balsa or do I have to cover with monokote or something? I have glassed the wings and fuselage can you help as I cannot find anything in the instructions. Thanks
RE: Airelons /rudder on TF Gold Edition Spitfire
I used coverite on the rudder and elevators and skinned my ailerons. I used 1/64" ply on the ailerons. If I were to do it again, I would stick to balsa.
Scott
Scott
If the controls surfaces are to be covered in sheet balsa, it would be supplied in the kit and mentioned in the instructions. The actual, full-size aircraft had fabric-covered surfaces, so you need to use the covering material of your choice. Painted fabric-types will be the most realistic.
My Feedback: (13)
the ailerons were sheeted with metal on the full size airplane TF recomends covering with a shrink type covering I used 1/16 balsa to sheet the ailerons and Ultra coat for the rudder and elevator then painted the camo and undersides with lustre-coat paint.
As BigTim stated, the MK IX had metal covered ailerons. The rudder and elevators were still fabric covered.
I used 1/64" ply to cover the ailerons and coverite for the rudder and elevators. If I were to do it again, I would have gone with balsa fort the ailerons instead of the ply.
Scott
Scott
