GP Spirit Kit
GP Spirit Kit
The subject kit has a technical error in the drawings and instructions for the Bolt on Wing option. The directions and plans show the location for the forward wing bolt in the wing that does not accurately line up with the instructions for drilling the forward wing bolt hole. When I followed the directions for installing the forward wing bolt plate (1 inch piece of 1/4" ply) and installed it in the indicated position in the plan, when I drilled the hole with the wing in postion with rubber bands as directed in the instructions, the hole ended up at the back edge of the plate. I had to install another piece of plywood behind that plate to be able to properly thread the hole.
Also, the plans and instructions do not adequately address the servo installation with the bolt on wing option. If installed per the plans, the servos are inaccessible due to the forward wing bolt on plate. The servos must be put in reversed, and the pushrods modified to fit the reversed installation.
Brad
Brad
