OOPS! Is this going to be bad?
SC
I am building a pt40 and happened to notice that when I mounted the tail fin I didn't get it perfectly straight. Stupid mistake, not paying attention and allowing myself to get distracted. It's not off by much, maybe 1/8", to the right. Is this going to hurt anything? Will it be fly-able like this? It's glued on pretty good so I don't know that I'll be able to get it off to fix it. Any other reccomendations or ideas? Thanks.
Tony
Tony
RE: OOPS! Is this going to be bad?
If the vertical fin is off by 1/8" chordwise, then you'll have noticeable yaw added, and the rudder and ailerons will have to fight it. That must be corrected...repeat MUST. You'll have to carefully cut the structure apart to fix it.
Now, if the vertical fin tilts off the vertical by a small amount, but is straight when you check front to rear, it won't affect much at all, and can be safely ignored.
NY
Buildind a GP PT-40 MKII just finished the fuseage ready to install thr tail what is CHORDWISE the other user said
it was off by a 1/8" and now he needs to remove his tail how do I get mine right,
SC
The CHORD is as you are looking at the plane from front (nose) to back (tail). How to get it right? Just go VERY, V-E-R-Y slow and don't do it when you might be distracted. Measure twice, mark twice and then recheck it. If you're still not sure then try to find someone to help. It's not a very difficult build. You can get it but if you're unsure don't chance it.
ORIGINAL: wzak29
