Mikado Logo 600SX ARF Heli MUST READ FULL DESCRIPTION 950.00 and up depending on elec
I picked up a Huge collection from a long-time R/C Heli Builder /Competitor who has passed away. We placed a bid on his fleet after seeing it. because we knew of him and were impressed with his build quality and choice of Helis. I'm not a Heli pilot but I have a Heli tech that has been in the game for years. He has inspected every unit we list.
Below is a video of other helis I will soon be listing. please enjoy
SHIPPING Buy soon Ill make the tree
The Quote is with heli in one piece except for the gear that we remove to save money. We can save even more if we remove the tail boom and all blades. We can ship anyway you choose.
Description
See Below
See the add-ons.
Blue font at bottom of this description
new heli lot in the shop #rcheli #rchelicopter
The video will open in a new window
Paste the link into a browser window:
Soon to come
Henseleit Helicopters Newly built and new kits. , GOBLINS, Guai, More Logos Helis up to 800 SIze
Below is info from online off the Mikado USA site.
Part Number: Logo600P
**********************NOTE:*********************** *
I will do my best to supply you with
2 or 3 Flight paks I need to test the cells.
Please ask any questions we will have, and my buddy the heli tech answer any you have. LOGO 600 SX is the next step in the LOGO 600 Series. The LOGO 600 SX keeps all the proven and popular components of the LOGO 600, while incorporating several new developments to sustain today’s technical requirements during extreme flight maneuvers.
- 600-620 mm main blades
- 10 S Lipo mit 5,000 mAh, 12 S Lipo, max 3,500 mAh
- light and durable fiberglass reinforced chassis frame with battery quick-release system
- alu-rotor head yoke with hollow 8 mm spindle shaft and extra-large thrust bearings (Ø 16 mm)
- direct servo link to the swashplate
- hollow main shaft with 10 mm diameter
- herringbone main gear with 106 teeth (module 1)
- motor counter bearing with additional main shaft support
- colored fin set in neon red, matched with the canopy
- extra-large 25 mm diameter tail boom
- detailed airbrush canopy
Rotor blades - 600/620 mm
RTF weight - ca. 3,4 kg
recommended batterie - 10S LiPo
Main gear ratio - 7,1 - 10,6
Main Gear size - 106 teeth Modul 1
batterie slot - 62 x 54 x 300 mm (HxWxL)
Length - 1250mm
Hight - 360mm
Width - 210mm
Kit - Kit with VBar Rotor Head
Accessories - Motor counter bearing with main shaft support
Manual - Detailed printed manual
Motors -
Motor Pinion -
ESC -
Vbar Electronic -
Servos -
Blades - Carbon main rotor blades
Tail Blades - Carbon tail rotor blades
Canopy - Airbrushed Canopy
WHAT is ON BOARD:
Motor
info below
It is set up with VBAR controller now, but I will remove it to lower the price.
It has 2 JR satellites installed I will leave them in place.
I can leave the Vbar system (with the software on heli with a price increase.)
I also have the newest version and the older version of the VBar Transmitter in stock and can sell as a package deal If you are interested.
SERVOS:
All MKS SERVO EQUIPPED
MKS Cyclic
Digitals
MKS 760 Rudder
and MKS BLS970s
Power switch and rc battery onboard
Blades:
Carbon Edge
Neon Tail Kit
Description
Mikado Logo 600SX 12-S
and then it was loaded down with electronicsSee Below
See the add-ons.
Soon to come
LOGO 600 SX
This heli has had a few flights/// everything looks fresh and tight all bearings were checked for end play and we stand behind everything we sell. This man had so many Helis it would take 2 months to fly one a dayPlease ask any questions we will have, and my buddy the heli tech answer any you have. LOGO 600 SX is the next step in the LOGO 600 Series. The LOGO 600 SX keeps all the proven and popular components of the LOGO 600, while incorporating several new developments to sustain today’s technical requirements during extreme flight maneuvers.
Specifications Helicopter
Rotor diameter - 1350 mm - max. 1450 mmRotor blades - 600/620 mm
Length - 1250mm
Hight - 360mm
Width - 210mm
Content
Motors -
Motor Pinion -
ESC -
Vbar Electronic -
Servos -
WHAT is ON BOARD:
Motor
Scorpion HKIV-4035-560KV 12-S
With Escinfo below
SERVOS:
MKS Cyclic
Digitals
MKS 760 Rudder
and MKS BLS970s
Blades:
Carbon Edge
Neon Tail Kit
