Novus FP N125 Issue. Please Help
Hey,
so i just bought a novus fp n125 and i'm loving this little heli! it's so nimble i love it (and its amazing outside). i am having one issue though. when i put the cyclic stick forward all the way (100%)and backwards all the way (100%) it makes a nasty clicking or tiny knocking noise. it sounds really bad and i can't seem to find what it is. i'm curious if anyone else has had this problem or if someone knows how to fix this. any help would be great
Thanks</p>
Hi, I also have an FP125 but have never had that problem. I wonder if could it be one of the servos?? Do you have a hobby shop nearby that sells that heli? Maybe they will know what the problem is.
Sorry I can't help - would really need to see (and hear) the heli to help you more.
UT
It sounds like a servo problem for sure! more of, a stripped gear, and if the servo is still working for the most part, it would be the topmost gear aka, the gear that spins the least.. ive had this problem several times.. its as simple as taking the gear out and spining it a little bit so that when you give it full cycilic forward or reverse, the stripped part, or the part missing some teeth, will stay in the back outta the way.. i have serval 450's that if you opened them up, there missing a couple teeth on the back of their gear :P
