Helimax This is for all your Helimax questions and comments.
axe cp thread
Old 05-30-2007 | 08:05 PM
  #1001
Heliko's Avatar
Default RE: axe cp thread
TP 1320's are the best, but the DN Power or Mega Power 1350mA 15C packs work great too and their half the price!
  #1002
Thanx chaseman81,
I'm all ready looking into that battery. How long does the factory battery last? Trust me I plane on going VERY SLOW with this.
Old 05-30-2007 | 09:24 PM
  #1003
Helidirect has the megapower lipo's and also has a fairly reasonable align charger/balancer for a little over $50. The megapower batteries there are already set up to work with the align charger. Just get some deans mini plugs and solder'em on. ready to roll!
Old 05-30-2007 | 09:25 PM
  #1004
Stock battery gets about four to five minutes of hop huvering, and about three minutes on a constant hover.
Old 05-30-2007 | 11:02 PM
  #1005
My Feedback: (8)
I am selling some new and used (very little use) OEM chargers and Nimh packs on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...6090&rd=1&rd=1
Old 05-30-2007 | 11:09 PM
  #1006
Attention children!!! I have found the solution to taming the big hairy beast known to us all as the AxeCP!!!!!! Being an RTF means that corners get cut to save money on the end product. This is one robust heli however look at the radio.... hmmm a very basic radio with some eCCPM firmaware built into it.
Lets take my experience for example: I got a TRex and installed the AxeCP radio with my old Piccolo receiver. While running the Axe radio I noticed that the TRex was extremely responsive to the point of barely being able to control it. In fact it felt like a really big AxeCP!!!!
So I go out and bankrupt myself on a DX6. Used the settings called out in the TRex manual and guess what? The TRex screamed and flew all over the place. Dumbed down the throttle and pitch curves and added some expo to the aileron and elevator to soften them up and now I can hover the TRex within 10" off the ground without much of a hassle!!!! Try hovering the Axe with the stock radio anwhere withing 2 feet of the ground and trust me that you are in for a fight!!
Now I wish I still had my AxeCP just so I can set up the DX6 to fly it. I bet that a stock AxeCP would be a dream to fly with a DX6 or Futaba 6EXH even using the stock 3-in-1 as opposed to a separate gyro!!!
In short, the cure for an Axe wound? A better radio.
Old 05-30-2007 | 11:48 PM
  #1007
DriveWRX's Avatar
ORIGINAL: alienteabagger
Yes, the Axe flies sooo much smoother with a better radio.
I have a DX7, switched out the stock receiver with an AR6100 and kept the stock 3n1.
After the installation of the better radio equipment, I could hover side-in and nose-in with relative ease thanks to some Expo. Never was able to do that with the stock TX. Transition from Normal to Idle was smoother too using the Throttle and Pitch Curves. If you can, invest in a good computer radio. You won't regret it.
I think that I would still add a HH Gyro though. I was still fighting the tail more than I liked. [&o]
That's my biggest gripe about the Axe, tail control. And because of this, I am moving on to a belt tail heli. Don't get me wrong the Axe is a good heli. It's even better with a good radio and a HH gyro. But for me, I would rather invest my money on a non-motorized tail machine.
BTW, my Axe is for sale with extras. Check my profile. Link is in Main Profile Page.
Old 05-31-2007 | 12:30 AM
  #1008
Heliko's Avatar
Hey WRX it just so happens that Freestyle Hobby has a belt drive tail conversion coming out in about a month. I've been looking at CP tail helis as well, but I want to stay with or close to the Axe's rotor diameter so finding one has been a challenge.
ATB, when my AXE was totally stock I had no problem hovering steady a couple inches off the ground as long as it was tail-in. All my hovering was done IGE because the basement has a low ceiling. I did have a problem with side-in though, but not because of ground effect. It was hard to chase the tail while attempting side-in. After the 240 went in with the BL set-up I was still using the stock Tx with no problems. Side-in tail-in IGE no problem. I like having to barly move my fingers to control the cyclic. In fact my 7CHP felt numb compared to the Axe. So I increased cyclic sensativity.
Old 05-31-2007 | 03:39 PM
  #1009
DriveWRX's Avatar
ORIGINAL: Heliko
That's very interesting.... do you know what the cost will be?
ORIGINAL: Heliko
I found one: [link=http://www.twf-sz.com/english/products.asp?prodid=0198]ESky Honey Bee King V2[/link].
Same class size (slightly bigger, 600mm rotor), same price (slightly cheaper).
I have one and really like it! I did go BL and 2.4Ghz on the King which helps!
Old 05-31-2007 | 03:54 PM
  #1010
Heliko's Avatar
ORIGINAL: DriveWRX
I figure it'll be around $70-80. I think that's what the other conv. kits cost. I didn't ask when I emailed him though. Actually I was surprised they had one in the works so close to release.
That's funny. The V2 is the same heli I mentioned in post #985. Great minds think alike and all that.[sm=idea.gif]
As I said in that previous post though parts support is sketchy. I saw it at Helidirect. They carry some of the parts, but it seems like the rest weren't available. I read some of the King V2 thread at RG Groups which seems to support this too. After the blade grips shortage with the Axe there's no way I'd buy another heli without abundant parts support
Old 05-31-2007 | 04:10 PM
  #1011
DriveWRX's Avatar
ORIGINAL: Heliko
True, very true. Parts support is a major consideration. I'm just hoping that, in time, parts will be readily available. So, in the meantime, I'm being very careful!
Old 05-31-2007 | 07:45 PM
  #1012
My Feedback: (8)
Hobby Town has the CP for 147.00
Old 05-31-2007 | 09:41 PM
  #1013
Replacing the Main Rotor Gear, justed stripped all of the teeth off it. OOOOOPPPPPPSSSS What are you going to do. Who has the trick. I am getting hung-up on the Canopy Mount. It looks like it is glued to the main frame. Any help would be great. This things is a blast.
Thanx
Old 05-31-2007 | 09:44 PM
  #1014
Heliko's Avatar
Why are you pulling apart the frame?
Could you not just slide the shaft out?
Old 05-31-2007 | 09:46 PM
  #1015
Never Mind I got it right through the top. Now I hope my LHS has a replacement . They probly don't Have to place an order with Tower
Old 05-31-2007 | 09:59 PM
  #1016
chaseman81's Avatar
Riders in flint has gears 6-7 bucks and a few other parts Hobbytown doesn't really carry but the will order
what happen Jeff?
Chaseman819
Old 05-31-2007 | 11:27 PM
  #1017
Hm...I seem to have extra parts trying to put my Axe back together...
I took out the main shaft and two rings came loose. It's either the collar or the bushing - not sure which. It's part number 30 and/or 25. *shrug* Their circumference is too big to fit inside the bearing and I'm not sure if it should be on top of the bearing or hang below. Anybody have any idea? Anybody have any idea what I'm talking about?
Old 06-01-2007 | 12:48 AM
  #1018
chaseman81's Avatar
Just Listed on Ebay Axe CP Heli W/ Spktrum DX 6 2.4 Ghz/ TP 11.1 1320 LIPO
http://cgi.ebay.com/ws/eBayISAPI.dll...4093&rd=1&rd=1
heres the link. SON AND I ARE MOVING TO AIRSOFT AND NEED TO FINIANCE A COUPLE AEG GUNs AND GGB GUNS AND SOME BDU's and OTHER STUFF.
Hey I also have a Brand New Never been open OEM 3-1 esc/gyro. everybody A WHILE AGO said they'res wasn't working so... I called Heli-Max, cause thought mine might go bad. They sent me one. never opened it Make me an offer on it. Cause tomorrow I am listing on ebay too.
chaseman81
Old 06-01-2007 | 07:24 AM
  #1019
ORIGINAL: s_mcflurry
Those are shaft collars. One goes just under the upper bearing inside the top of the frame and the other goes above the lower bearing between the main gear and bottom of frame. The are supposed to ride snug against their respective bearings. These prevent any unwanted up/down mainshaft movement which would cause unwanted pitch changes.
Old 06-01-2007 | 11:57 AM
  #1020
Cool, ATB! Thank you very much. You're always there in a pinch. [sm=thumbs_up.gif]
Old 06-01-2007 | 10:26 PM
  #1021
BoysToys's Avatar
Well folks I think my 3 in1 is dead. I was flying today and had to adjust my tail trim all the way to the right to keep the tail steady. So I adjusted to bottom knob on the 3 in 1 then my heli started acting crazy. The trim pots on the 3 in 1 are not doing anything and my heli is almost impossible to control. I have gone from flying circles to fighting to keep from crashing into the ground.
How are Hobby Services about replacing the 3 in1 board? I will call on Monday and see what they say. If they don't replace it under warranty I don't know what I will do. I don't think that I can bring myself to spend $80 on a new one when I can put that $$ toward the T-Rex I want. I am thinking of just parting it out and saving my money until I can affort the T-Rex. In the mean time just keep practicing on Real Flight.
Old 06-01-2007 | 11:56 PM
  #1022
It could be your tail motor going south.
Old 06-02-2007 | 12:13 AM
  #1023
BoysToys's Avatar
I really wish that I would be that easy. However, I just replaced that tail motor a couple of weeks ago after it died on me. It flew fine for me earlier today then whe I went out tonight things really took a turn for the worse. I was barely able to keep the thing in the sky. The problem has to either be the receiver or the 3in1. Since the adjusting pots are not responding at all, and the receiver was just replaced 2 months ago, my money is on the 3in1. I just don't know if I can bring myself to spend $85 to get this bird back in the air. If I am going to continually drain my bank account, I would at least like to be able to fly in a steady breeze. Waiting for it to be dead calm outside and then chasing the tail around is starting to get old.
Ohh well I am taking the family camping at the beach tomorrow and won't be home until Monday. I will call Hobby Services and see what they have to say. Who knows maybe there will be alot of good Axe parts and 3 TP1320 lipos for sale of Ebay Monday night. If they offer to replace it I will go that route and keep flying this heli.
Old 06-02-2007 | 12:40 AM
  #1024
Heliko's Avatar
You know I was thinking BT. I don't see a problem with Hobbico covering the 3-in-1 under warranty, but this could be a good time to upgrade to a GY240 with a Pixie 7. If the main motor is still working then the 3-in-1 could stand in for a main motor ESC. The difference in flight control is huge. It does cost more money, but the gyro can go to the next size heli unlike the $85 3-in-1 which can't.
Old 06-02-2007 | 01:10 AM
  #1025
Doing this in conjunction with get a replacement 3-1 sounds the most feasable if you ask me. You could get a 400/450 class brushless motor and esc and reap the benefits of going brushless, Plus when you decide to upgrade to say a mx400 take that equipment off the Axe and replace it with the stock 3-1 and sell it to recoup some money for your new heli.
