AXE CP Lipo install
NY
AXE CP Lipo install
Hello
I have a few questions about installing a lipo battery and balance charger in my axe cp.
i have read alot about saftey / advantages of lipo batterys and chargers.
I have been charging the battery in my blade cX for a while and really like the way the balance charger that comes with it works...
my 1st question: can i use the blade cp pro [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLB0995]BATTERY[/link] / [link=http://www.horizonhobby.com/Products/Support.aspx?ProdID=EFLC3105]CHARGER[/link] is 10c/12.5c burst enough???
my 2nd question: can i balance charge [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNYJ1&P=7]THIS BATTERY[/link] with the blade cp pro charger?
it says .8a output so that would be charging this battery at under 1c so that would be o.k. right? is this only for the blade batt.?
my 3rd question: if i cant use the blade cp pro charger can i use [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXPZT6&P=7]THIS CHARGER[/link] with the GP battery
i cant find any info on the charge rate for this one but it looks similar to the blade cp pro charger setup
my 4th question: will the heli considerably loose power when the battery is low or should i get one of [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMHJ9]THESE LOA'S[/link]
Thanks!
~JaSoN
Thanks!
~JaSoN
