Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 Axe EZ swash plate >
Axe EZ swash plate
Helimax This is for all your Helimax questions and comments.
Axe EZ swash plate
Old 01-27-2007 | 09:01 PM
Default Axe EZ swash plate
Just bought an Axe EZ - my first heli. It was great the first few flights, but now it's uncontrollable. It looks like the swash plate will not stay together - the top part floats and the control has no effect on the blade pitch. I've tried pressing them together with pliers but it comes right back apart once the RPM comes up.
Anyone know how to fix this?
thanks
Old 01-27-2007 | 10:42 PM
Default RE: Axe EZ swash plate
I heard people were having that problem on the Blade CX also. (I never did) If I recall, they were CAREFULLY using a drop or two of CA. (Super Glue) on the edges to hold the tops on. Like I say, I never had that problem personally, but I'd make sure you either get a medium CA or 'Gel' Super Glue so it doesn't seep where you don't want it...
Search the Blade CX forums and you might find the answer there too.
Old 01-28-2007 | 07:17 PM
Thanks for the suggestion. I tried it but the gel super glue didn't help. Appreciate any other suggestions.
Old 01-28-2007 | 07:48 PM
I've heard of a couple of people with this problem but your best bet is to get a new swash plate, there only like $8. Good luck.
