GYRO and the AXE CP
#51
ORIGINAL: VBDave
This what I was talking about... No BEC / ESC used in this.. I just wonder if anyone has done this with the stock electronics in the Axe? EEEEKY?![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
[img][/img]
[img][/img]
#52
Yes but on the Telebee gyro the instructions say that the signal wire dosen't have to be hooked up because it locks itself into heading hold mode anyway.
#53
VA
( I just posted this on RCGroups too... You all might find it somewhat usefull)
Couple things found while trying this mod, and GREAT thinking Eeeeky!
First, to use ANY external Gyro without the HelixMax ESC Hack you'll need to do some setup and, depending on if the Gyro has remote gain control or not.. you may need your OWN RADIO.
In either case, you'll want to turn the Gyro Gain (Center Pot) down on the 3-in-1 to effectively turn OFF the built-in Gyro circuit so they don't compete with eachother.
For a GY401 (or other remote gain capable Gyros..) You will NEED YOUR OWN TRANSMITTER that allows you to set the gain on the gyro properly. [ I'm trying to replace the receiver / radio with the Futaba 6EX Fasst.. and that's NOT going well...] 20~40% gain seems to be working for HH mode on the GY401 as reported by Eeeeky. If you try to use a remote gain Gyro with the stock transmitter, the wiring forces the gyro to HH-MODE, but with 100% GAIN and you'll get nothing but huge tail wag! (And if you unplug the gain lead from channel 5 it will force the gyro back to Non-HH Mode, but with 0% gain so you can't fly that way either...)
Using the GY240 or Non-Remote Gain Gyro should just plug in as indicated and you'd manually set the gain on the Gyro itself. (I'll verify this later today if I can, but in theory it's a perfect match.)
The reason this method works is, you're letting the gyro do the rudder mixing from your radio and then using the servo output signal to drive the tail rotor ESC on the 3-in-1 as if the input was coming directly from the sticks. I'm going to say that neither Eeeeky nor myself will be held responsible for blowing your 3-in-1.. lol.. I'm sure there's some current issues we aren't aware of, driving the 3-in-1 from the servo output of the Gyro.. but who can resist? I know Eeeeky has been using his with this arrangement for some time and hasn't blown his 3-in-1 yet.. but use at your OWN risk!
If you want to play 'safe', use the Official HeliMax method linked to on the first page of this post. If you don't want the soldering, ESC, BEC, Arming issues and costs for the HeliMax thread.. Use this method.. AT YOUR OWN RISK!
Now... back to my radio woes...
Dave
PS: Quick Summary
GY401 or other Remote Gain Gyros..
1) REQUIRES your own transmitter/radio that you can set the Gain to 20~40% for the Gyro. (your results may vary)
2) Set Gyro Gain (Middle Pot) on the stock 3-in-1 down to 0
3) Gyro plugs into CHANNEL 4, GAIN LEAD into CHANNEL 5, Orange wire from ESC that WAS in channel 4 now goes to the signal lead on the servo connector of the Gyro. (Lt. Blue on the gy401)
GY240 or other Mechanical Gain (on the Gyro) type s..
1) Set Gyro Gain (Middle Pot) on the stock 3-in-1 down to 0
2) Gyro will plug into CHANNEL 4 (Rudder) and existing Orange wire from 3-in-1 plugs into the signal lead on the servo connector of the gyro.
3) Manually adjust gain as required.
Dave
PS: Quick Summary
#55
VA
Not unless you can hook up a POT or something to set the gain manually..
(Just testing with a CSW? HH gyro.. Don't like the Gyro, but it DOES work. It's a P.I.T.A to get the gain manually adjusted, and I had to actually turn the Gyro Gain on a little on the 3-in-1 to reduce the wag. Now it seems steady.. charging the new LiPo's and will give it a better run in a bit! )
Dave
Dave
#56
CO
I bought a CSM gyro and hadn't even used it yet when I read this off the [link=http://www.swashplate.co.uk/ehbg-v17/ch06.html]Swashplate[/link] site
so I returned it and got a GY240.
Most heading hold gyros (other than the Futaba GY series) seem to have drifting problems. This is caused by the gyro's expectation of the rudder "center stick" position being different from the transmitter's center stick position. This can be very frustrating because the one click of the subtrim can be the difference between the heli slowly turning left and the heli slowly turning right.
The Futaba GY series seems to calibrate the center stick position at power-up which eliminates the need to use rudder subtrim. Therefore I highly recommend the GY240 or GY401 for beginners.
#57
MI
Thanks VBDave, for the comment. I didn't see that Helimax had you buy a separate ESC. Has anyone else used the 3-1 for an ESC to the Tail off of a HH Gyro? Does it work? Does it hold up?
#58
Did the gy240 upgrade per specs of helimax. Not really happy. I have been messing with the gain to try to eliminate wag but can't get it.
Are you other guys getting a solid tail or do you still have a slight wag. I'm using the 1320 lipo and blade cp tail blade.
Karl
Karl
#60
Last week I got some interference and my blade cp, crashed, after 4 hours of searching for it I gave up, the next day I tried again and found it but the interference made the motor keep running so it heated up and burned my blade , total loss. I can do very mild acrobatics and I was wondering If I go for a helimax axe cp or the blade cp pro which one would you recommend? thanks for your help.
Ps: would a gyro help for either one? I am thinking on the futaba Gy 240 would it help?
#61
ORIGINAL: VBDave
Dave
Dave
That's exactly what I was thinking. I unfortuantely was thinking too far into the future myself and purchased the GY401 and Mini-ESC thinking of moving it to a different copter in the future. However, it seems that unless I throw a POT in the way to control the gain, it may very well be wasted money unless I buy a whole new Radio/RX setup.
So, with that in mind, and with the open statement that I am an electronics tinker, do you have any recommendations of Ohm rating for a micro POT for this interconnection? I may just pick up a box of assorted POTS from RadioCrack, but I figured that I would ask first.
TIA!
#62
![](/forum/images/badges/premium_vendor.png)
ORIGINAL: VBDave
A pot wont cut it.
#63
hey I got the axe cp I want to take out the stock raido and the 3-1 and put in a 401 and a 6ch pcm raido what elas would I need to put in to it am I missing any thing
#64
TX
questions guys: as a new-b and one that is not mechanically inclined is it folly for me to not invest in a heading hold gyro? ...is it critical to learning to fly this heli?
thanks
thanks
#65
MD
Others may have other opinions, but my suggestion is not to put a lot of accessories or new parts on. A heading hold gyro is a great help, but it's hard to put in the Axe. I'd suggest RealFlight for your computer, ping-pongs for your real heli, and Radd routine to get used to the bird before you take it off the ground. Take it slow and you'll have a lot of fun; push it and you'll spend a lot of money. Good luck!
#68
hye guy i just put a futaba gy240 and a elertrifly c-12 esc in my cp and when i plug in the battrey the tail just spins i have the gain at 60 and the dir on rev and the avcs on any ideas
#71
ORIGINAL: VBDave
#72
CO
ORIGINAL: handofdume
does anyone know what color the signal lead is on the gy240?
I tried to use my GY240 with the 3-in-1. It didn't work very well. I couldn't get it dialed in. Either the gyro wouldn't keep the tail from spinning or I would turn up TR trim and the tail motor would just pulse. VERY, VERY, ANNOYING!!! I have a full BL set-up on the way though. This is my second 3-in-1 the first had tail controller problems too, and all I can say is I can't wait to eliminate the POS.
I hope you have better results than I did.
#73
thanks i have a seperate esc, im gonna give it a shot wo the mod. if it becomes a pain im going with the cut and solder method. ill keep ya posted
