Helimax This is for all your Helimax questions and comments.
Power Issues
Old 02-24-2007 | 01:59 AM
Default Power Issues
2 week Newbie with a brand new AXE CP. very few, minor crashes. All of sudden, having power issues. Will charge stock battery for an hour or 4 and then install in heli. wait for gyro stable and turn everything on.
I can power on throttle and rotor will turn, but if i attempt to throttle up farther, I lose power and heli eventually stops. if i just leave it at a low throttle setting, the rotor will turn and then eventually slow and stop. yes, i waited until charger showed a "green."
Also, are there any detailed manuals on adjustments, wiring, etc.? I noticed that the orange wire was off the circuit board and found where it should go on this message forum.
Thanks and wish me luck
Lou
Old 02-24-2007 | 02:07 AM
Heliko's Avatar
Default RE: Power Issues
I heard the a bunch of the chargers that came with the Axe CP's were defective. That is most likely your culprit.
