Axe CP Vibration???!!!!
MI
ORIGINAL: Heliko
Pilot Light does the vibration get worse as speed increases?
I've got the tracking nearly perfect. Its gotta be in the blade balance, but I don't have a balancer.
CA
ORIGINAL: PilotLight
I found a way to balance the blades using ordinary household items: 1 paper clip, 2 rubberbands, 2 CD jewel cases, a dictionary, a ruler, felt-tip pen, scotch tape. I based my procedures off of T-Rex Tuning.
I bent/broke off one of the straight pieces from the paper clip and threaded it through the holes on the blades. This was held in place by the rubberbands and wrapped them above and below enough times to hold the blades straight (at the 3 and 9 o'clock positions).
I placed the extended paper clip pieces on the upright CD jewel cases to find the lighter blade.
I placed the ruler inside the upright dictionary and held the ruler perpendicular to the table. Using the ruler, I followed the directions as described in the T-Rex link above to find the center of gravity. I placed enough tape at the appropriate end of the blade to match the center of gravities between the blades.
I then rigged it back up using the paper clip and rubberbands and then balanced their weights with more tape.
CO
Pilot Light it doesn't sound like anything is bent. It also sounds like you got it pretty well balanced already if the bad vibes are only showing up at high RPM. To go further the only advice I can give involves a balancer to balance the head as a unit.
Here's the way I do it using a helimax balancer.
First using the balancer normally I find the CG of the blades. So far the blade CG have been the same.
Second I pull apart the balancer. I have one of it's legs screwed to a board. I found that a spare mainshaft I have fits inside the leg's bearings perfectly
Third I pull the head off the heli mount it on the balancer and with the blades off to balance the flybar. This method it a bit more exact than measuring distance.
Fourth I install the blades and apply tracking tape to the light blade until they sit level. This not only balances the blades, but also compensates for any balance variations in the head assembly. I also colored the washers and on the head to mark each side and to make sure when the blades come off they go back on the same side.
This has produced very good results for me. My Axe is very smooth even at full throttle which with the BL set-up is topping 3000 RPM.
Hope this helps.
Hope this helps.
ON, CANADA
I just caused a vibration in my CP by a blade strike in my living room. After repairing the broken blade grip I found the CP vibrates pretty bad right at the point of liftoff. It seems to hover ok, but the vibration is pretty bad.
What is the most likely cause of vibration due to a blade strike? Everything was smooth prior. Thanks!
CO
Canadianlst if the main shaft still looks straight and true I'd check for a bent feathering spindle.
I've noticed a pattern with the Axe. If the blades strike something hard like wood or metal it usually damages the blade and breaks a grip, but hitting something soft usually bends the mainshaft and/or the feathering spindle.
