Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 axe cp  cyclic problem >
Helimax This is for all your Helimax questions and comments.
Old 04-04-2007 | 08:28 AM
Default axe cp cyclic problem
Hi !!
I broke the one blade grip and I got new grip. after that i can not control cyclic (forward. backward, left, right),
throttle and rotor control is OK. litte bend flybar and Vibration.
i check movment of servos with TR. i think it works OK looks same with manual
may be TR problem..?? i drop one time..^^;;
any possible reason ??
Old 04-04-2007 | 10:13 PM
Default RE: axe cp cyclic problem
You know the blade grips are showed backwards in the manual right?
Old 04-05-2007 | 06:32 AM
yes...
i tried both way....
thank you
Old 04-05-2007 | 06:38 PM
If your flybar is bent and causing a vibration thats your problem.Everything has to be perfect,flybar,paddle alignments,blade tracking,everything.You just need to check everything to make sure it is aligned and working correctly.
Old 04-06-2007 | 06:28 AM
check to see that your swashplate is not apart....i just had 2 crashes today because of it...i bought 2 different ones fron 2 different stores...they bolth came apart...and make sure there are not any broken teeth in your servos...........
