Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 Is this normal??? >
Is this normal???
Helimax This is for all your Helimax questions and comments.
Is this normal???
Old 04-17-2007 | 06:30 PM
Default Is this normal???
On my Axe CP, when you move the left stick to the right, the tail goes to the left & vise versa. Is this normal or do I need to reverse the input on the transmitter? Thanks in advance!
Old 04-17-2007 | 07:37 PM
JJP9398's Avatar
Default RE: Is this normal???
That's normal when you get into FF and turning it will make sence. You will move both sticks on the radio in one direction, its called flying the nose.
Old 04-17-2007 | 07:46 PM
This depends on the helicopter's flight orientation. If the helicopter is hovering in front of you and the nose is facing you (nose-in hover), then that's normal. But if you're hovering and the tail is facing you and yet the turns are reversed (left rudder stick = right turn and vice versa), then there's a problem. Most likely you'll need to check your transmitter and make sure that the servo reversing button for the rudder is set on normal position.
Old 04-18-2007 | 07:52 PM
Thanks guys! I feel like an idiot. As soon as I posted this, I figured it out[sm=idea.gif]
