Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 AXE CP tail rotor question? >
Helimax This is for all your Helimax questions and comments.
Old 04-29-2007 | 12:37 PM
Default AXE CP tail rotor question?
I just fired up my new cp for the first time last night. My question is, should the tail rotor work when you push the rotor stick to the left? Thanks for help.
Old 04-29-2007 | 12:44 PM
SchoooBaka's Avatar
Default RE: AXE CP tail rotor question?
Depending on how far you push the stick to the left, it may or may not.
Left rudder input will decrease tailrotor speed and right rudder input will increase tail rotor speed.
Old 04-29-2007 | 06:06 PM
Does the tail rotor turn all the time? When I apply left rudder. i get nothing.
Old 04-29-2007 | 06:11 PM
SchoooBaka's Avatar
With full left rudder it won't spin. It depends on how much throttle you're using too though; i think.
The tail motor counteracts the tourqe produced by the main motor and blades.
As long as the nose rotates right with right rudder input, and left with left rudder input, it's working fine.
Old 04-29-2007 | 06:41 PM
mythsc281,
The tail rotor will spin after you apply 50% to 75% or more throttle. Tail rotor speed changes with left-right motion of the left stick, and it depends on how much throttle you apply for the tail rotor to start spinning.... at least on the Axe CP that's what I've noticed.
Under ideal conditions, the tail rotor should always spin, even before lifting up, so the heli would have a perfect lift up without spinning left or right, right from the moment it's still on the ground.
It only makes sense, don't take my word, since I'm not an enginner, just someone that uses common sense, and that has a strong background in Electronics and some handyman skills.
Imagine your heli lift up without any tail rotor speed, it would spin on its own axis like crazy. The tail rotor speed counteracts the main rotor, spinning faster or slower, moves the tail one direction or another... so in my humble opinon, under ideal conditions, the tail rotor should always spin, right from the moment the helicopter is taking off.
Adjusting the pots on the electronic board you should be able to have the tail start spinning even at low throttle settings, therefore having a more stable lift up without the tail spinning and the heli turning on its own axis at lift up time.
That's only my humble opinion, which doesn't necessarily means that's the way it is. ;-)
Regards
Old 04-29-2007 | 10:22 PM
Heliko's Avatar
Myth it might be better if you viewed the tail rotor less like a rudder and more like an anti-torque device. Since it's a fixed pitch prop it can only yaw the heli to the right. To yaw left the heli uses the torque of the main rotor so the tail rotor reduces speed and/or stops on left turns.
